DIY: swapping in a manual from an auto transmission
Old 11-23-2014, 09:20 AM
Repstyles
Repstyles's Avatar
Default DIY: swapping in a manual from an auto transmission
Looking for some info or recommendations on swapping out that automatic transmission for a 6/5spd manual gearbox that will mate up to an Ls block. I know the running gear from camaro/trans am are the go to swap, and likely that is what I'm going to do. I was wondering if there was any one that has done this swap & may have found other transmission options that work well. Also what troubles am I looking at for this auto to manual swap? Thanks for any helpful input
Old 11-23-2014, 03:32 PM
travlee
Master
travlee's Avatar
Received 9,044 Likes on 6,510 Posts
and you posted this in the forced induction area why? you will need the engine harness for the manual. if you are doing an LS swap you would prob get better answers on what would go best on an LS forums is my thinking
07ZEKE
08-23-2021 09:15 PM
burglapfd
12-06-2020 01:04 PM
Jambo016
09-16-2016 01:08 PM
_bit
10-02-2015 07:49 AM
Quick Reply: DIY: swapping in a manual from an auto transmission
