Master
ecu, wiring harness, i believe the engine is a little wider and definitely taller, so you would need a new hood, the radiator support in your car isn't setup to handle the dual intakes, not sure if the de trans would work on the hr motor.....
i don't think you can do it cheaply, could it be done.... with enough time money and cussing i am sure it could be
DKMura did it in his track car ... far far far not worth it!
Really only worth it if you have a built race chassis and you don't want to start over building a new chassis up to spec ( cage, sound deadning removal , wire harness removal)
