You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
We've taken all of the guess work and research out of putting together the Pathfinder Cooling Mod Package. You can order everything you need quickly and easily from Z1. The Pathfinder Cooling Mod allows you to add a rear coolant crossover to promote more even cooling and water temps throughout your engine. We keep all of these componants in stock and have installed them in house so we know that they work and fit together.
We don't have a tech sheet on it just yet but I can have something put together and sent out with it. That would be no problem.
It is a fairly straight forward installation although there is a good bit involved. The lower plenum (collector) has to be removed to install one of the coolant lines. It could be done in car although it would be tough. We generally install this package with the engine out of the car.
what do you do about the passenger side cooling rail where the pathy rear coolant log attaches...
the Z has a funky end on it where it attaches at the passenger side...
im guessing cut and then hose clamp??
-j
I haven't done one of these myself so I'm not 100% sure on that, but maybe this pic can answer your question for me? If not I'll be glad to check with the service department and get an answer from them.
Also, what goes here?? where the red arrow is pointing! do you plug it?
- J
I Just got the pipe from the Dealer the pipe comes plugged (Welded) from the Factory, there`s a small bypass hose right next to the red arrow in the 1st picture they did install the nipple to reconnect the hose, i don`t think that this small hose will affect anything i`d rather remove the hose plug the other side (the small golden nipple on the right of the 2nd picture) and call it a day
__________________
2004 Desert Platinum G35 Coupe 5AT Mods: Nismo CAI V2, MD 5/16 ISO Thermal Spacer, DC Sports Ceramic Headers, Tomei Testpipes, Fujitsubo Legalis R Catback Exhaust, UTEC + Tuner WB.
interesting, mine wasn't plugged.....im gonna find out what the threading is.
-J
__________________
04 PPW Touring - My favorite mod is my short Dodge Avenger antenna
I also want to keep the passenger side by pass coolant hose, and not block it off.
Is the 1/4" compression thread the same as 1/4" NPT?
On the Pathfinder casting, there is a thick, plugged unused position for a fitting directly above where you tapped into the casting. Any reason you didn't use that one?
