Fontana Nissan proudly carries Cosworth Quality Internals for your 350Z!!!
Cosworth:
Cosworth leverages its successful motor sport pedigree, performance technology expertise and globally recognized brand to provide high quality engineered solutions for a growing customer base across diverse industries.
The company is home to leading edge engineering, world class manufacturing and comprehensive test facilities. Our business is geared to deliver smart solutions and exceptional service to customers around the world.
Over the years we have developed in-depth knowledge of engines, engine components and engine management systems. This has been successfully used to supply engines to some of the most successful Formula One teams and vehicle manufacturers. Our unprecedented success in the performance market has fueled customer demand from diverse market sectors. In addition to the traditional markets, Cosworth is engaged in designing and developing, engines and components for marine, locomotive and aerospace applications.
A rigorous and comprehensive product quality assurance policy is implemented across our business. Quality engineering is embedded in processes, procedures and team ethic; we operate under recognized quality management systems.
We have a dedicated workforce, focused on providing high quality products and solutions to meet ever demanding customer needs.
Cosworth Featured Products:
Twin Plenum Inlet Manifold
The Cosworth Twin Plenum inlet manifold for the Nissan VQ35DE has been engineered for increased performance featuring increased plenum volume for improved high rpm power with torque enhancing velocity stacks to maintain mid range performance. With performance derived from countless hours of development including computational fluid dynamics, the Cosworth Twin Plenum Inlet manifold is perfect for both normally aspirated and forced induction applications. Performance increases will be significant on engines with improved exhaust and intake system including optimized ignition/fuel maps with increased maximum rpm limiter. Cast from lightweight aluminum alloy with carbon fiber end caps and includes all required mounting hardware.
Can be used with the factory fuel rail system or the Cosworth High Volume Fuel Rail kit.
Nissan VQ35DE (3.5L) High Volume Fuel rail kit
The original factory VQ35DE fuel rail arrangement is limited in performance. The Cosworth VQ35 High Volume Fuel System features high volume anodized fuel rails, with o-ringed fittings and is fully configurable for various applications. Each system includes sleeved high pressured fuel lines along with a CNC machined distribution block that includes an additional port for various sensors. The Cosworth High Volume Fuel Rail System can be used with original or various aftermarket injectors.
Forged Piston Set
The piston is one of the most important components within the engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces of 8500g. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth pistons are manufactured using the same methods as our Formula One pistons and include features such anti scuff skirt coating, heavy duty pins, polished top and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design . Set includes six pistons, pins and clips. Rings not included.
Camshafts
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs are the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new billet and finished using the same procedures we use in our extreme level race engines. Cosworth camshafts are the perfect compliment to our CNC Ported Big Valve Cylinder heads. Our cams are profiled to increase engine response and torque and are fully compatible with our CNC Ported Big Valve Cylinder Heads. Sold in a matched set of four camshafts. Upgraded valve springs are required use with these cams
All of these parts and more can be ordered through us at Fontana Nissan! Please PM for special my350z.com pricing!!!
Scott
