You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Z1 Motorsports High Flow Intake Kits, In Stock $138.00
Z1 High Flow Intake Package
This package includes both the high flow Z1 Motorsports "Z" Tube assembly and a new Z1 Motorsports High Flow intake filter for a quick and easy upgrade package.
Kit includes:
Z1 "Z" Tube Assembly W/ 2 silicone couplers in your choice of black, blue, or red & 4 hose clamps.
Your factory mass air flow sensor is required and must be reinstalled in this package.
The Z1 Motorsports high flow air intake for a 350Z or G35 (Non HR) features a high flow serviceable cone filter, cast adapter including velocity stack, easy installation. A great choice for all 350Z & G35 models.
Getting air into the engine is key to producing power. The stock airbox system uses paper filter elements and the path of air through the box offers resistance which means less air gets into the engine. Upgrading your filtration system to a high-flow filter that also features a velocity stack will enhance your engine's breathing capability.
A velocity stack is a radiused port of which funnels the air into the mass airflow unit - this guides the turbulent gases as they pass through the filter element and enhances flow characteristics. The K&N style filter is one of the best filters available. It offers superior airflow over the rest and it is cleanable using the K&N filter cleaning kit available below.
The Z1 Motorsports "Z" Tube Assembly allows you to replace the restrictive OEM air intake piping on your 350Z or G35 (Non HR models) with the high flow Z1 "Z" Tube. Made from lightweight aluminum and available in your choice of chrome plated, polished, or black enamel finishes.
Heat shields for this package will be available soon.
