The New AEM Infinity PNP ECU 350Z
Standalone Plug-and-Play EMS for the 350Z
AEM Infinity-8 $2349.95 (MSRP $2611)
AEM Infinity-10 $2699.95 (MSRP $2999)
AEM PNP 350Z Harness $208.30 (MSRP $232)
The Infinity EMS delivers high-end engine control for the racing masses at a fraction of the cost. Combined with AEM’s industry leading after-purchase support system, including free technical support, the Infinity is the ultimate engine control solution for both professional race teams and weekend track cars. Concept Z Performance is also now one of the few authorized Infinity dealers in the US!
Infinity is compatible with most factory and performance aftermarket sensors. An ECU Setup Wizard takes complex calibration setup work and simplifies it through a smart interface that features tabs for quick set up of vital engine functions. Each tab includes a description of the function, and the entire interface can be customized, allowing you to create the perfect tuning environment, with high resolution 3D graphics to enhance the tuning experience. A powerful input simulator feature allows the user to simulate operating conditions. This allows users to validate tuning changes before running the engine. Tune and log using IP-67 rated weatherproof connection cables (weatherproof PC cable sold separately).
Infinity’s airflow model based systems greatly reduce the amount of time it takes to set up and tune an engine by eliminating many of the lookup and trim tables (correction tables) necessary in previous generation ECUs. The Infinity’s airflow based, or volumetric efficiency (VE) based models calculate an engine’s requirements in real time based on an advanced algorithm that has various modes for calculating air flow. Tuning around a VE model allows you to make changes quicker and more accurately than any other tuning solution!
ADVANCED TUNING PACKAGE (Included at no additional charge for a limited time!):
Advanced Tuning Functions:
-No-lift shift
-4-wheel speed traction control
-3-step launch control
-Drive by wire
-4-stage nitrous control (coming soon)
Advanced Tuning Hardware Outputs:
-1 high side driver (coming soon)
-2 H-bridge channels
If purchasing the ECU alone, you will also need the AEM 350Z Plug-and-Play Harness. We also offer a complete kit including everything you need:
PM me for the best price shipped!
