FS: Injector Dynamics ID2000 injectors (6)
Let me add that these injectors are designed for someone eventually looking to hit something north of 850 whp on e85. On 93 octane pump gas, at a 1k rpm idle, the best AFR you will likely get is in the mid 13s (not bad and idles perfectly fine but that is what I meant by overkill for my street car). On e85 you can easily reach stoich at idle. They work fine but my turbos will never be able to generate the air to match the fuel supply these injectors can provide, so I figured I'd step down to 1300cc injectors and bump the fuel pressure up a bit to compensate.
These injectors have worked perfectly for me and they will for you too. Nicely sealed back up by Dynosty. (Thank you Dustin!)
11-09-2020 10:27 AM
