FS: VQ35DE engine part-out
No disclaimer made on fitting rwd -- maxima owners know rwd configuration don't fit in fwd cars so it's assumed 350z/G owners know this not direct fit but internal parts are similar
Engine is 2008 maxima VQ35DE (supposedly better than 02/03 DE Maxima--ALL parts sold as is not guaranteed to work for rwd without modifications)
Everything (except block and crank) available from this engine so whatever you need just ask!
Timing covers $150 each excl. water pump
Heads $300 or $225 each (excl. Cams, bolts, sensors etc.)
Valve covers $30 each (front back Pcv damaged)
Plenum $50
Timing chains & guides $120
Rods $150
Pistons $150
Injectors 2008 (different spray pattern - not sure if that matters) $50
Coils $75 (only 5)
Water outlet $40
Power steering pump with lines all assembled including brand new high pressure hose $150
Camshafts $100 each / $150 pair
Crankshaft position sensor $55
Camshaft sensors $50 each $80 both
Knock sensor (2003) $75 obo
Plenum $50
Rods $150
Pistons $150
Coils $75 (only 5)
Water outlet $40
liqalu04
01-02-2022 12:58 PM
04-04-2016 07:52 AM
