FS: 350z BLOCK CRANK...
350z BLOCK CRANK...
I have a 2003 350z block crank girdle and studs for sale. This block is by far the cleanest engine I had ever torn down. The reason for teardown was cylinder 5 was not giving compression based on a broken piston ring; which was found. I look meticulously in that particular cylinder wall and found no scratches. Looking for 500 firm without paypal fees and shipping on the buyers expense.
this engine has only 30,000 miles i bought it from the buyer on this forum i can have him vouch for me if needed. Engine was beyond clean when bought and was shocked on clean this engine was!!
Parts are obo without paypal fees or shipping.....
upper oil pan with crack but professionally welded 50.00
intake manifold and lower intake combo 130.00
stock headers with o2 sensors 100.00
5 good stock pistons and rods 75.00
stock cams 100.00
one girdle and baffle plate 30.00
stock heads with cams with cam sprockets and tensioner 250.00
6 good coil packs 100.00
rear coolant with knock sensor and one sensor on it 70.00
timing chain with little ones too 70.00
stock oil pan 20.00
3 oil pumps 40.00
timing cover with rear 120.00
4 mains 100.00
two solenoids 100.00
one oem crank pulley 50.00
water pump 30.00
stock cams 100.00
stock oil pan 20.00
3 oil pumps 40.00
4 mains 100.00
water pump 30.00
liqalu04
01-02-2022 12:58 PM
wanderingstuden
01-28-2016 07:03 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
