FS: Aps big oil pan with fins >cheap
APS big oil pan with fins >cheap
APS OIL PAN FOR 350Z/ G35 vq de
ITS USED,COMES WITH ALL HARDWARE..VERY GOOD CONDITION, CLEANED 95% PERCENT OF THE OIL RESIDUES.
Please see details below from the website and usage.
http://www.airpowersystems.com/350z/sump/sump.htm
APS Air Cooled Cast Alloy High Capacity Engine Oil Pan
High engine horsepower demands the very best in lubrication, particularly when the Z is driven under extreme motorsport conditions such as Autocross, Drag racing and Circuit racing. In that light, APS has developed the ultimate engine oil pan that not only improves engine oil supply to the pick-up, but also increases the engine oil capacity by a huge 1.25 quarts. This alone reduces oil temperature and helps to protect the Z engine.
In addition, the APS oil pan has multiple air fins cast on the external surface of the oil pan to further assist oil cooling under extreme engine operating conditions.
Crafted in cast alloy and then precision machined, the APS engine oil pan has provision for twin oil return lines in turbocharged applications and with additional baffles in the oil pan, oil surge under track/race conditions is reduced significantly.
The APS High Capacity Oil Pan can be installed on normally aspirated, supercharged and turbocharged Z engines. Delivered complete with provision for twin oil return lines for turbocharged applications and blank-off plates when normally aspirated and includes detailed installation instructions.
In addition, the oil pick up assembly is relocated 1/2" lower to match the now deeper oil pan floor depth via a precision CNC machined manifold and positively sealed with Viton O-rings. These components are included with every APS oil pan.
The APS oil pan is a "must-have" item for every high horsepower Z regardless of whether or not you hit the track.
these are very rare and not found easily....asking 300 obo
TEXT ME OR EMAIL 510364 8206
keywords
Nissan 350z 370z g35 g37 nismo stillen ams aps vortech greddy tein veilside mobil 1 z1 motorsports motul
keywords
