FS: VQ35HR Shortblock w/ forged internals
Old 07-21-2015, 08:04 PM
venture210
venture210's Avatar
Default VQ35HR Shortblock w/ forged internals
MODS CLOSE
VQ35HR short block fully built, using Wiseco forged pistons 8.8:1 CR 96mm, Brian Crower sportsman forged connecting rods with ARP 2000 3/8" rod bolts, OEM bearings/ thrust washers, and ARP main studs. All machine work was done by Duffin Engine Service in San Antonio, TX. All bolts torqued in 5ftlb increments until final torque spec. All bolts torqued in sequence according to the FSM. Grey RTV applied according to FSM.
VQ35HR bare long block: $3000 + shipping + paypal fees
If you have already own an HR engine I will also trade this engine plus cash on your end.
FOR EVERYTHING BELOW: $5000 + shipping + paypal fees
ALL reasonable offers will be considered.
Updated: OEM vq35hr head gaskets, OEM main seals, and ARP L19 head studs used.
Torque specs (ft*lbs)
Main bolts: 60
Rod bolts: 42
Head studs: 95
Clearances (inches)
Main bearings: 0.0032
Rod bearings: 0.0035
Ring Gaps: 0.020
Piston wall clearance: 0.020
These tolerances were chosen to run 15W-40 oil and a generous amount of boost and a goal of at least 600whp.
Short block assembled with pistons facing up
Short block assembled with crank and rods facing up
A little hard to see, but heres the detail on the rod bolts.
Got the heads back form the machine shop. Nice and clean with a light mil to clean off the gasket material and dirt. New OEM head gaskets on the left and ARP L19's
Receipt of machine shop work. Everything checked out way better than expected.
Cleaned the deck mating surfaces really good
Little hard to see but yeah, they are indeed ARP L19's!
Somehow, the ARP kit has one washer bigger than the others so I'm waiting on the new one to arrive to put the other head on and finish the engine.
Both heads on and torqued to 95 ft*lbs in sequence according to FSM and in 5 ft*lb increments to insure "even-ness" of loading. Cams also on now
Timing components on and yes on time. Aligned with ovals on left bank and circles for the right bank regarding the secondary chains. Cyl 1 is approx at TDC and all dots line up. I lubed up a few things and cranked it over twice to check for binding and it rotated without problem
Buncha new O-rings and the main seals.
As soon as I put the lower pan on, I noticed it was slightly warped (I guess from prying it off initially) so it will need another one to be slapped on. I will still ship the engine with the existing pan. CZP sells them individually.
JK40C transmission approx 60k miles. Black sensor plug on the left of the tranny in the picture is a little banged up. Sensor most likely still works but attaching the plug may be tricky.
07-08 engine and interior wiring harness with HR ecu
Twin disc clutch. Very dirty but also barely broken in.
HR waffle twin intake manifold + throttle bodies + all hoses + air boxes (missing driver-side filter) + transmission mount
The built HR as it sits today with all the accessories mounted.
venture210 is offline
Old 07-25-2015, 02:16 PM
venture210
venture210's Avatar
BUMP
Old 07-29-2015, 06:33 AM
venture210
venture210's Avatar
Bump
Feel free to send low ball offers, I'm still trying to get a feel of what this short block is actually worth. Companies whom sell crate motors and such seem to price these closer to 4k with a core charge.
Old 08-07-2015, 04:31 PM
venture210
venture210's Avatar
BUMP
Old 08-09-2015, 02:06 PM
cincysilvias14
cincysilvias14's Avatar
if i didnt just buy my car id be all over this glws
cincysilvias14 is offline
Old 08-10-2015, 06:53 AM
venture210
venture210's Avatar
Thanks bud
Monday BUMP
Old 09-04-2015, 11:55 AM
venture210
venture210's Avatar
BUMP
Old 09-26-2015, 08:21 PM
SNSH1NE_Z
SNSH1NE_Z's Avatar
How many miles are on engine?
SNSH1NE_Z is offline
Old 09-30-2015, 05:34 PM
venture210
venture210's Avatar
Original engine was claimed to have roughly 30k miles, I'm taking the heads to the machine shop tomorrow morning for a little touch up work and then slapping them on. Will be selling this as a built long block shortly.
Parts to be added will be new OEM head gaskets, ARP L19 headstuds, new seals and such.
pics and price updates will follow accordingly.
Thanks for your interest
Old 10-10-2015, 11:20 AM
venture210
venture210's Avatar
BUMP
updated
Old 10-13-2015, 06:04 PM
venture210
venture210's Avatar
BUMP
Old 10-26-2015, 08:07 PM
venture210
venture210's Avatar
Bumpity
Timing chains are set. Going to do the chain cover, oil pan, water lines, mounts, and exhaust manifolds in the morning
Old 10-26-2015, 08:20 PM
Stolly08
Stolly08's Avatar
Originally Posted by venture210
Bumpity
Why are you building this if your not going to use it?
Stolly08 is offline
Old 10-26-2015, 09:05 PM
venture210
venture210's Avatar
Lol but the plan was to build it and then fab up a custom turbo kit to shoot for at least 600whp. I came to the realization that a stock HR and boost would be more than enough.
I figured the engine would sell better if it was built so some one could just do a straight drop in. That's why I'm completing it. All the forged parts had already been purchased so it would be wasteful not to finish it. At this point I want to see someone else boost this thing and have fun with it.
Stolly08 (10-26-2015)
Old 10-26-2015, 09:37 PM
Stolly08
Stolly08's Avatar
Lol but the plan was to build it and then fab up a custom turbo kit to shoot for at least 600whp. I came to the realization that a simple supercharger on my stock revup would be more than enough.
Gotcha! I'd love to have it lol but I have so much other stuff I'm buying currently. Lol
Stolly08 is offline
Old 10-26-2015, 09:41 PM
venture210
venture210's Avatar
Well keep in mind the price is very negotiable. Pm me what you think it's worth. I'm not looking to make a killing on selling this thing (although the extra dough would be nice)
Old 10-29-2015, 07:26 PM
venture210
venture210's Avatar
BUMP updated
Old 10-30-2015, 10:12 AM
venture210
venture210's Avatar
Friday BUMP
I will also be up for trading engines + cash if you have a running vq35hr!
Old 10-31-2015, 08:32 AM
roplusbee
roplusbee's Avatar
Friday BUMP
If you still have this near the end of November, I will see about making a deal.
roplusbee is offline
Old 11-01-2015, 06:51 AM
venture210
venture210's Avatar
Sounds good brother!
November BUMP
Quick Reply: FS: VQ35HR Shortblock w/ forged internals
