Engine Intakes, Exhausts, Clutches, Turbos, etc...
Z1 Motorsports: Tomei, JWT, and BC Cams
Old 11-10-2015, 11:45 AM
Z1Motorsports
Z1Motorsports's Avatar
Default Z1 Motorsports: Tomei, JWT, and BC Cams
Tomei PONCAM 350Z/G35
Tomei Poncam camshafts are designed as a "drop in application!", No dialling in required as the nock-pin has been pre-set so that the timing is set for you.
Tomei Poncams are designed to work with the standard valve springs and offer the best drop in performance gain for both street and track use. These cams will work with the OEM ECU settings and aftermarket ECU if you want more customised settings.
Buy Now For $790
All Tomei Cams Can Be Found Here!
____________________________________________________________ ________________________________________________
JWT VQ35DE Cams
JWT S1 Cam Specs
260 DEG DUR. / .428"(10.9MM) LIFT, INT. ADVANCED 2 DEGREES. ** NOTE: THIS CAM UPGRADE MAY REQUIRE THE IDLE RPM BE SET TO 850 RPM TO PREVENT POSSIBLE STALLING AT IDLE. 2004+ LEV II VEHICLES DO NOT ALLOW FOR IDLE ADJUSTMENT AND SHOULD NOT USE THESE CAMS WITHOUT SEEING OUR TECH SECTION ON IDLE STABILITY MODS. WILL NOT WORK ON 2005+ REV-UP ENGINE WITH EXH. CAM CONTROL.
JWT S2 Cam Specs
256 DEG DUR. / .430"(10.92MM) LIFT, INT. ADVANCED 2 DEGREES. ** NOTE: CAM UPGRADES MAY REQUIRE THE IDLE RPM BE SET TO 850 RPM TO PREVENT POSSIBLE STALLING AT IDLE. S2 CAMS ARE DESIGNED TO DELIVER SIMILAR POWER TO JWT S1 CAMS, BUT WITH MORE IDLE STABILITY. WILL NOT WORK ON 2005+ REV-UP ENGINE WITH EXH. CAM CONTROL.
JWT S Series starting at $1,198.00
All JWT Cams Can Be Found Here!
Brian Crower VQ Cams
Brian Crower VQ35DE cams are manufactured to top-quality specs. Brian Crower high performance camshafts for the VQ35DE powered 2003-2006 Nissan 350Z and the 2003-2007 Infiniti G35 are ground on state-of-the-art CNC cam grinders to insure accuracy and tolerances to within .02mm. Every Brian Crower camshaft profile has been prototyped and dyno tested for proven horsepower results prior to placed into mass production. By grinding cores in high volume, Brian Crower, Inc. is able to pass the cost savings on to the end user. These are top quality cams for the VQ35DE 350Zs and G35s at an affordable price.
All Brian Crower cams are checked on a high speed, sub-micron accuracy measuring gauge. The Adcole Camshaft Measuring System uses individual measuring heads for each cam journal and cam lobe, with .01 micron resolution, taking one datum point each 1/10th of a degree or 3,600 data points per revolution. Measuring camshafts for rise error and chattermark detection, this model can measure 200 parts per hour. Brian Crower 350Z/G35 cams are available in 264/264 specifications giving you nice street manners and a slight lope at idle. These are excellent all purpose spec cams. We suggest using Brian Crower 350Z/G35 valve spring and retainer kits for the 264/264 cams.
Brian Crower VQ Stage 2 Cams Start at $1,048
All Brian Crower Components Can Be Found Here!
Valve Springs, Retainers, Shims, and Install Kit Can Be Found Here!
Z1Motorsports is offline
terrasmak (11-24-2015)
Old 11-13-2015, 10:34 AM
Z1Motorsports
PM for more information.
Old 11-17-2015, 10:22 AM
Z1Motorsports
Add the Nismo oil pump to your order and experience 8000 RMPs.
Old 11-24-2015, 08:49 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
If I end up doing a rebuild, I'm going to have some questions on the Tomei cams.
terrasmak is offline
Old 11-25-2015, 04:46 AM
Z1Motorsports
You can ask us anytime.
Old 12-11-2015, 07:02 AM
Z1Motorsports
Bump
Old 01-14-2016, 11:03 AM
Z1Motorsports
In stock
Old 01-27-2016, 07:15 AM
Z1Motorsports
Increase your top end
Old 04-04-2016, 07:02 AM
Z1Motorsports
Bump
Old 04-11-2016, 06:00 AM
Z1Motorsports
Bump
Old 06-06-2016, 07:37 AM
Z1Motorsports
Bump!
