Enjuku Racing - Walbro 400LPH w/ Install Kit
Vendor - Former Vendor
on
Walbro 400 LPH In-Tank Pump with Installation Kit
The new 39/50 DCSS pump has been designed around the proven 39mm armature ("motor") that has been used for many years, Coupled with the proven armature are two sets of turbine blades set in paralled on a single impeller shaft. This design allow fuel to pass through two high pressure pumping channels delivering fuel in a manner to work with the high pressure demand of today's direct injection system.
Technical Pump Specifications
Overall pump lehgth: 121mm
main Housing Dia.: 39mm
Lower Housing Dia.: 50mm
Fuel inlet Dia.: 11mm OD
Fuel Outlet Dia.: 11mm OD
Flow rate: 400LPH @ 40PSI
Test Voltage: 13.5 Volts
Kit Includes:
Fuel Pump
Universal Install Kit
In Stock and Ready to Ship!
$179.99
