FS: BIllet Mains, Pistons, Cams
Old 07-03-2016, 07:14 AM
meatbag
meatbag's Avatar
Default BIllet Mains, Pistons, Cams
GTM billet main caps, $750
CP Pistons, 98mm, 2618 material, extreme duty wrist pins, ceramic top coat and moly side coatings, $1000
JWT S7R cams, came from my motor, removed only to go to Kelford Cams, $500
Tomei 280in/280ex cams, new in box, $800
meatbag is offline
Old 07-05-2016, 06:10 PM
Guilty1s
Guilty1s's Avatar
I wish those S7R's could be used on a non-revup, I didn't know there was such s big difference even in factory specs. Also wish those tomei's werent so aggressive. bump for a great deal on all this stuff.
Guilty1s is offline
Old 07-05-2016, 07:37 PM
meatbag
meatbag's Avatar
You can use them if you get a set of the JWT exhaust cam gears to adjust the centerline to match nonrevup specs
meatbag is offline
35reilly
10-26-2019 11:04 AM
NA&CH
Exterior
07-17-2016 02:53 PM
DarkCreep
Lighting
07-05-2016 08:48 AM
x CoNFuZiioNz I
06-29-2016 04:59 AM
x CoNFuZiioNz I
06-26-2016 05:36 PM
Quick Reply: FS: BIllet Mains, Pistons, Cams
