FS: Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons
Old 09-15-2016, 11:32 AM
qew
qew's Avatar
Default Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons
As the title states If you want big power here is your chance to come up. Im not gonna end up using this stuff as I have a r33 gtr I will be focusing on. I bought this as a package deal a couple years ago from someone who had the work done and as I'm doing, went with another project.
The following parts are new or machined and have not been used or installed. This kit was made to fit together so I'm selling it all together unless I get buyers for each item. Buyer pays shipping Ill cover paypal. local 9095441954.
$8000.
Parts were for my 03 350z. They are for the vq35de.
1) Machined and Sleeved Block with head studs. Note some nuts missing from the Arp studs.
2) Two Port n polished heads with bigger valves, I beleive they are super tech 1mm bigger with upgraded springs. The cams that come with it are some early 272 cams that I'm not sure who makes them as there aren't any part numbers just specs. Im guessing tomei.
3) Brian Crower billet crank 4.1 liter 88mm stroke.
4) Carillo rods.
5) Je pistons.
Thanks for looking.
Attached Thumbnails Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2845.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2846.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2858.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2860.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2863.jpg
Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2867.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2868.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2849.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2847.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2851.jpg
Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2854.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2855.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2852.jpg   Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons-img_2850.jpg
qew is offline
Old 09-22-2016, 05:13 PM
qew
qew's Avatar
Bump..Make me a serious reasonable offer.
qew is offline
Old 09-22-2016, 05:28 PM
craig12895
craig12895's Avatar
If you can somehow confirm the maker of the cams I would be interested
craig12895 is offline
Old 09-23-2016, 03:05 AM
qew
qew's Avatar
I'm almost 100% sure the cams are early versions of the tomei pro cams because they offer 11.3 lift on their intake cams. While the exhaust is 11.0 lift.
qew is offline
Old 09-23-2016, 03:19 AM
craig12895
craig12895's Avatar
Do you know how many miles are on them? I can call tomei later and see if they know of any way to identify them for sure
Old 09-23-2016, 06:38 AM
qew
qew's Avatar
I don't think these cams were ever ran, they look new. I have more pictures in detail of the cams that show no wear on the lobes nor the journal areas. Im almost certain the springs are also upgraded as I currently run 272 jwt c8 cams with recommended upgraded springs on my single turbo z, which I purchased before running across this stuff a few years ago. I can send you the pictures if you'd like just text me. They have some stamps on them too. But nothing significant such as a part number.
I had this same issue with some hks cams that came on my rb26 engine in my r33 Gtr. I was in contact with hks in emails but at least I believe those had an hks stamp, lift, duration etc. but no part number and I wanted the cam card but in the end couldn't get an exact card for those specific specs it has stamped. I ended going with new hks cams with a higher 272 duration but at a lower lift compared to what was on the other cams.
qew is offline
Old 09-23-2016, 10:36 AM
craig12895
craig12895's Avatar
Just sent you a text message with some info regarding Tomei cams
Old 09-30-2016, 10:44 AM
qew
qew's Avatar
Bump price drop 7400 boo.
qew is offline
Old 10-13-2016, 10:51 AM
qew
qew's Avatar
Bump..... 6800. shipped domestic with fees covered.
qew is offline
Old 10-19-2016, 11:15 AM
qew
qew's Avatar
Bump.. Info update pistons are custom 9.0:1 compression. Didn't say on the box,had some interest and contacted je pistons and found that out. Kit makes engine 4.1 liter.6800.
qew is offline
Old 11-14-2016, 11:40 AM
qew
qew's Avatar
Bump... reasonable offers considered,prefer to get it sold as a set,the sleeves are already bored for these custom 9:0;1 pistons and everything is ready for assembly and make big power.
qew is offline
Old 11-14-2016, 03:25 PM
ogiehooker
ogiehooker's Avatar
I'll take crank and rods...
ogiehooker is offline
Old 11-15-2016, 10:03 AM
qew
qew's Avatar
If I can get interest in the Block, heads and pistons we may be able to work a deal.
qew is offline
Old 11-21-2016, 03:50 PM
Total D
Total D's Avatar
Default Block
Im interested in the block, do you know the bore size? How much for just the block. D said he'd take crank and rods.
Total D is offline
Old 11-21-2016, 10:44 PM
qew
qew's Avatar
I'll pm u. Well that's bidders on the the block ,crank n rods. Bored to 3.9". Bored to fit those je pistons.
Any takers on the heads with cams and springs and the je pistons?
qew is offline
Old 11-22-2016, 11:19 AM
Snitkercms
Snitkercms's Avatar
I want heads bro just sent u a text
Snitkercms is offline
Old 11-22-2016, 12:05 PM
Logiqal
Logiqal's Avatar
Do you have a part number on the rods? I may be interested.
Logiqal is offline
Old 11-22-2016, 04:16 PM
qew
qew's Avatar
Logiqal. Rods are niq35 65676s00. Go for over 1500 new, which they are but will be less tag that if I sell em.
People who interested I have responded by pm to all your requests. Heads are spoken for as I've verified and spoke to the member Snitkercms on the phone I f I split everything up.Counter offer something fair, if I don't get responses by the end of this week I will sell to someone interested in the whole package so make your offers, make your moves. Thank u all for your interest.
qew is offline
Old 11-24-2016, 11:40 PM
qew
qew's Avatar
Sale pending
qew is offline
Old 12-01-2016, 03:09 PM
fronkk
fronkk's Avatar
PM me if heads are still available
fronkk is offline
Quick Reply: FS: Big Power!! Sleeved block,ported heads,billet Bc crank,carillo rods & je pistons
