Engine Intakes, Exhausts, Clutches, Turbos, etc...
CZP Rear Gallery Gasket Kits Ready to Ship!! Check it out!!
Old 02-07-2017, 11:58 AM
Mike@CZP
Concept Z Performance
Mike@CZP's Avatar
Default CZP Rear Gallery Gasket Kits Ready to Ship!! Check it out!!
Selling these CZP Rear Timing Internal Oil Gallery Cover Plate Gasket Sets. You can also order the replacement allen bolts for these through the same link. Let me know if you have any other questions. Simply click on "Add to Cart" to order online.
Those rebuilding their VQ35DE have probably realized that it's impossible to get replacement gaskets for the oil gallery plates on the rear timing chain cover, as Nissan only ever sold these gaskets with the complete cover. Now, we're producing our own replacement gaskets for these parts!
Made from Syntheseal gasket material, these gaskets are designed specifically for sealing oils (as well as other fluids like fuel and water), with temperature tolerances up to 350°F (180°C). They fit perfectly and exceed specifications of Nissan's own paper gaskets.
Specs:
Density, g/cc (lb/cu.ft): 0.82 (50) (min)
Compressibility, % (at 34.5MPa): 28-42
Recovery, %: 20 (min.)
Tensile Strength, AMS, MPa (psi): 6.9 (100) (min) if greater than 1.2mm gauge. Otherwise 8.62 (1250) (min)
Fluid Resistance, IMR903 Oil: 30% change in tensile strength (max), 7% change in thickness (max), 30-45% change in compressibility (max).
Fluid Resistance, Fuel B: 7% change in thickness (max), 25-50% change in weight (max)
Binder Type: Nitrile Butadiene
CZP Rear Timing Internal Oil Gallery Cover Plate Gasket Set, VQ35DE - Nissan 350Z 03-06 Z33
Mike@CZP is offline
Jimmy Mack (05-17-2020)
Old 03-01-2017, 02:41 PM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 03-20-2017, 08:07 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 04-07-2017, 12:53 PM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 04-28-2017, 01:04 PM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 05-22-2017, 09:17 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 06-13-2017, 07:48 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 07-11-2017, 09:29 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 08-07-2017, 07:53 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 08-22-2017, 10:59 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 09-15-2017, 11:31 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 10-19-2017, 02:09 PM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
Old 11-21-2017, 10:21 AM
Mike@CZP
Mike@CZP's Avatar
Bumped!!
Mike@CZP is offline
