Headrests!!! They do exist!
on
[QUOTE=gringottwhy is my head flopping around? QUOTE]
If your head is just naturally (or unnaturally as the case may be) flopping around, I think you have a more serious problem than a headrest that doesn't work how you want it to...
In how many cars does your head actually touch the headrest without leaning back to begin with? probably not too many..
Just did a little research and found this:
http://www.icbc.com/library/research..._resultsPU.asp
Looks like most cars are pretty crappy. Don't see the Z specifically, but it's probably in line with other Nissans. Still, this modification doesn't neccessarily make it better; couldn't know that without proper testing.
BUT, from reading this article, it looks to be a step in the right direction... I'd have to change my assessment of this mod to "good job!"
Article:
http://ip.bmjjournals.com/cgi/content/full/11/2/97
Article:
on
I just traded a 03 Caddy CTS for my Z, the head rests in it were adjustable (tilted forward/backward). I always rode with them just touching the back of my head. Although it was a altogether different seat (also had lumbar support)you could sit all the way in the back of the seat and your whole upper body felt supported. It seemed to make a big difference in comfort. You will be always better off with the least amount of head movement in any crash.
on
Didn't really care to read the whole post, but you should have gotten some EBay head rest pillow. You are causing yourself to have a Upwer-Extremity Postural Distortion, which basically means a forward head/bad posture. Just though u should know, i do this for a living.
on
The headrests are not active. I have taken the seats apart... To convert to leather. There is nothing inside other than supportive materials. Also, this mod is absolutely NOT pushing my head forward. It merely is far enough forward that when I lean my head back I am no longer staring at the ceiling, but comfortably at the road. During normal driving, my head does not always touch... Which tells me this has ZERO affect on my posture... It is basically for longer trips in the car to obtain better comfort. )
on
Hyundai has pretty awesome headrests in their cars. Like the Azera, took one of those to vegas, it sticks out and supports ur neck real well....
BTW... I think im gonna do this mod, should help on the morning commute.
Kick *** idea. The only thing that would top your (properly corrected) headrests would be a tilt option.
Nissan must have had to go through a crash test with the 350Z to meet North American safety standard in order to be allowed to sell the car... So I would think they would have used a crash test dummy to measure the neck pressure in a crash with it's design...
While this is a pretty um... unique "mod", I'll guess this design was not crash tested to see if this add-on would stand different kinds of force or how different this mod would change the outcome of the OEM design in a crash.
I think I'll stick to the OEM design which was crash tested to meet North American safety standards, but that's just me.
Now if you did this to give yourself some place to relax your head while driving a sports car... I guess it's a nice design, but I wouldn't try to call it a mod to make it safer like some others have tried to point out.
P.S.
Go buy a Subaru
P.P.S. Twin turbo chargers are NOT crash tested!!! If you are now planning on getting rid of your tt Z... I will take that unsafe vehicle off your hands at a great price of 90% off
General & Tech Moderator
Posting on any thred over 1 year old will bring flames, fyi.
08-06-2021 06:19 AM
Workshop12
03-23-2020 01:45 PM
Vigman
11-17-2015 04:34 AM
Beater350z
09-09-2015 03:36 PM
