Sponsored by:
Sponsored by:
Kirk Racing Roll Bar Install
Old 12-26-2006, 10:51 AM
SpoilsofWar
SpoilsofWar's Avatar
Default Kirk Racing Roll Bar Install
Well I put the roll bar in today... 6 1/2 hours later :
Disassembly:
Had to cut this panel for the rear leg braces to bolt up to the fenderwell:
Amp rack and box removed:
This is where the main hoop bolts in:
Bar in:
Main hoop mounting, inside:
under the car w/ backing plates:
continued...
SpoilsofWar
installed:
I modified my amp rack for the rear legs to pass through:
Some cool shots my gf took:
Well it was a PITA for sure, but well worth it
Old 12-26-2006, 12:09 PM
ZlleH
ZlleH's Avatar
Just curious, why did you install the roll cage?
I thought a roll cage is installed if you were thinking of putting on CF doors, but it doesn't look like your roll cage covers anything near the door area.
Or do you track somewhere near cliffs that you need more roof enforcement then what the car comes with just in case you go off course? Or is this roll bar more for stabilizing the car?
Old 12-26-2006, 01:48 PM
SpoilsofWar
Well first off its a roll bar, not a roll cage, so theres nothing in front of the seats. Although it would not be hard to have some additional bars fabricated and then bolted/welded to the main hoop.
The bar is for added safety when tracking the car, and also adds chassis reinforcement. With the roll bar, coilovers, sways bars, and gt spec braces, the car is now very very stiff
Old 12-26-2006, 02:26 PM
twenzel
twenzel's Avatar
Chassis rigidity and harness mounts are some reasons why you would want this bar.
Old 12-26-2006, 02:29 PM
smellslikecurry
smellslikecurry's Avatar
i recommend coating the underneath bolts with something so they dont rust...that and congrats...things a beauty!
Old 12-26-2006, 03:47 PM
bverschage
bverschage's Avatar
nice job!
I will install mine in the next few weeks
Old 12-26-2006, 04:40 PM
jakesford
jakesford's Avatar
looks nice, but I would have it welded in if it were me.
Old 12-26-2006, 07:12 PM
Citrus
Citrus's Avatar
Looking good man. Always enjoy seeing new parts on your car.
On a side note, ditch the Corbeau belts. They work loose very easily after a few months. When I autox'd my RX-7 I had corbeau belts and I'd tighten the s*#@ out of them before a run. By the end of the run, they'd have a couple inches of play. Not good. We use Crow Enterprizes 5 point 3in belts in our track Vipers and they are 100x better than the Corbeaus and fairly affordable. They're still as tight as when we bought 'em last year after an entire season of track use.
www.crowenterprizes.com
Old 12-27-2006, 04:45 AM
gringott
gringott's Avatar
Thank you for posting the detailed pictures.
Old 12-27-2006, 05:10 AM
Monsta
Monsta's Avatar
Good Job!!
GO ARMY!!
Old 12-27-2006, 06:04 AM
THE TECH
THE TECH's Avatar
Nice install!
Old 12-27-2006, 06:11 AM
skidmarq
skidmarq's Avatar
Looks amazing! Which style of Corbeau seats are those? FX1s???
Old 12-27-2006, 06:57 AM
SpoilsofWar
The seats are Corbeau Forza's.
I haven't had any issues with the harnesses loosening yet, but thanks for the heads up and I'll keep my eye on them.
And I already hit the bolts and backing plates with spray paint to keep to keep them from rusting and to make it easier to see if they're backing out at all.
Thanks for the props guys!
Old 12-30-2006, 02:39 AM
kingsti
kingsti's Avatar
what was cost of roll bar?
Thanksh
Old 12-30-2006, 04:43 AM
eagletanggreen
Got Track!!!!!
eagletanggreen's Avatar
can you post pics of the other side of thespeaker box?
Old 03-01-2007, 12:52 PM
SpoilsofWar
Not sure what you're looking for... Pics from the front looking back towards the amp rack?
Old 03-01-2007, 01:20 PM
Risky_Business
Quadrant 987c
Risky_Business's Avatar
Default Nice but...
I've always hated the idea of a roll bar. Probably because it has the word "roll" in it.
Old 03-01-2007, 02:10 PM
mdracer76
mdracer76's Avatar
Looking good!
Old 03-02-2007, 12:41 AM
Volk350Z
Master
Volk350Z's Avatar
nice......
Quick Reply: Kirk Racing Roll Bar Install
