Removal of oem spoiler...
on
I looked around the forum for a how to.. I am installing a nismo CF wing, but first I need to remove the oem spoiler. Who has done this themselves, and what problems am I going to run into? Any tips? please let me know, as I would rather do it myself, than pay some jerk at the body shop do it. Thanks.
Do WHAAAAT!?
Originally Posted by Nexx
remove the hatch lining.
Biggest advice. S-L-O-W-L-Y!
on
Remove OEM spoiler
Hi,
I'm new to the forum. I took the lining off , took the two lugnut off from the inside of the trunk. I use fising line to go through between the spoiler and the trunk but I could only get as far as to the two bolts. The bolts look like they are installed to the wing. How did you get it off. Thank you in advance for your advice.
on
Remove oem spoiler
Thanks everyone for your help. I was able to go underneath the trunk lid and loop the fishing line over the bolt to remove the rest of the tape. Took much longer than I thought. Couldn't have done it without your help. Thanks!!!!!
on
I was not successful with the fishing line or dental floss buy I was able to take a plastic pry tool and apply some heat with heat gun and once it got hot came up pretty easy
Hope it helps
Hope it helps
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
