Sponsored by:
Sponsored by:
JDM Fender Sidemarker Install
Old 05-09-2011, 04:35 AM
  #41
BulletMagnet
BulletMagnet's Avatar
Yup, European models have them as standard.
Could post up a pic with measurements later if that helps
Or......
You could install 370Z side blinkers instead, which I find to be a cleaner solution
Old 05-09-2011, 04:43 AM
  #42
pfregeolle
pfregeolle's Avatar
I have seen the 370Z blinker mod, the only thing that bugs me about it is that the 350z's never came with it stock. So although it might look clean, there is a bit of a cheese factor to me haha
Exact measurements would be super helpful, Bullet. Someone previously in this thread mentioned 15mm was the distance from bottom of the emblem to top of the blinker, maybe you can verify?
Old 05-09-2011, 05:28 AM
  #43
pfregeolle
pfregeolle's Avatar
Hmm AsianRicerChick, who has had hers on since like 2005 said she found some sockets that fit from Password:JDM.....just found these, maybe they'll work???
http://passwordjdm.com/PasswordJDM-S...-P133C320.aspx
Old 05-09-2011, 07:44 AM
  #44
VQpoweredZ
VQpoweredZ's Avatar
I understand the JDM bling factor. But I couldn't see myself doing this because there is no going back if you don't like it. But I do think it looks pretty cool.
Old 05-09-2011, 07:54 AM
  #45
pfregeolle
pfregeolle's Avatar
I plan on buying some white LED bulbs to use instead of the amber colored ones, and I believe it should look pretty clean. I think as long as I get the measurements just right etc etc It should come out perfect.
Old 05-09-2011, 09:32 AM
  #46
BulletMagnet
Pics as promised
So looks like the bottom edge of the side emblem to upper edge of cut-out is 1.45cm
Old 05-09-2011, 09:57 AM
  #47
pfregeolle
pfregeolle's Avatar
WOW! That's extremely helpful man! Thanks much!!!
One more thing, are the bulbs the same as the license plate bulbs? I know in the manual they're referred to as T10 size, but it's the same as a 194 bulb too. Thanks a lot Bullet!
Old 05-09-2011, 09:59 AM
  #48
BulletMagnet
Glad to be of help to a Z-brother from another mother, haha
Old 05-10-2011, 05:26 AM
  #49
joekool
joekool's Avatar
nothing personal but I think you guys are smoking crack, the side marker looks **** and kills the clean look of the fender. I wish our australian spec didn't have the side markers
If I was you guys I would replace the Z emblem with the one on 370z's.. So it will still look clean and have the functionality of a side marker.
Old 05-10-2011, 01:10 PM
  #50
BulletMagnet
That's what I said.....
I wish I could have mine without the additional sidemarker.
If I could drive over, I'd swap fenders straight away, haha
Old 05-10-2011, 08:48 PM
  #51
joekool
joekool's Avatar
I've actually bought the 370z emblem/side markers so I'm gonna get that installed and have my body shop remove the side marker and patch up the hole.
Old 05-20-2011, 08:49 AM
  #52
pfregeolle
pfregeolle's Avatar
Well I just made up my template last night out of cardboard with the dimensions given! I'm gonna dig into the project this weekend probably. Going to get the holes taken care of, make sure the lenses and all fit, and then go from there. I'll figure out lighting afterward.
Old 07-26-2011, 01:29 PM
  #53
dcains
dcains's Avatar
Originally Posted by Andres_Miami
Yeah... I guess, I was looking for a low budget project... I found the harness in other thread though, I wonder if someone has done it since then.
Just to combine everything to one thread:
http://mynismo.com/products/?id=5306
Well, if Kwame says this isn't the correct harness, and I believe him, where can I get the correct harness(es)? Anyone have a Nissan Part#, or anything else which might help? Thanks in advance.
Old 07-26-2011, 01:33 PM
  #54
dcains
dcains's Avatar
Are these in fact the correct harnesses? From the pic in post#1 of this thread, looks like they could be.
Old 07-26-2011, 01:35 PM
  #55
Stock2Autocrozz
Stock2Autocrozz's Avatar
I can hook up BNIB extra fenders dirt cheap for those of you afraid to do it...I say go forth with impunity, thne if F'd up...just PM me, lulz
Old 07-29-2011, 09:40 AM
  #56
dcains
dcains's Avatar
So, I ordered the side lights from nismoraceshop.com, and they're back-ordered for 4-6 weeks, which is fine. I also ordered the wiring harness/sockets from passwordjdm.com, and they just arrived. This is what's pictured on their site:
The douchebags sent just the wiring pictured on the right, but no sockets as pictured on the left of the image.
Anyone know another source for the sockets? I don't really need to spend $20 for $0.50 worth of wiring.
Old 07-29-2011, 09:50 AM
  #57
pfregeolle
pfregeolle's Avatar
^^ Yea I noticed that too when I was searching on Password:JDM's site for something that might work. In really small print somewhere on the page where you ordered that, it says "This is for the wire only, light sockets not included." That immediately turned me off and I went for a different solution.
My GF actually has a 2000 VW Passat, and I checked out the sidemarkers that come on her car. Well they hold a 194 (T10) bulb which is what the JDM 350Z markers use, but they don't have a real way of attaching to the lenses themselves, just like a rubber boot type thing. So I went ahead and ordered two sockets from RockAuto.com. They actually come all as a kit, with the socket, wire, and lens for like $5.00. Here is the piece I ordered:
http://www.rockauto.com/catalog/moreinfo.php?pk=707013
They're also the same markers used for Jettas and Golfs / GTIs. I just tossed the sidemarkers and used the light socket assembly and wire. And they've worked great so far! I realized I never took pictures of mine installed, so I will get some soon and upload them when I get a chance!
Old 07-29-2011, 10:06 AM
  #58
dcains
dcains's Avatar
Thanks a million. They're listed at $2.30 each, and I'm ordering a pair right now.
Old 04-04-2012, 11:46 AM
  #59
nismopoping
nismopoping's Avatar
Originally Posted by johzp
Yeah I saw your pictures but, didnt want to bother you with exact measurements. I guess i will just have to eyeball it also unless someone in any country besides the US can chime in?
Kwame: luckily it seems i got the factory harness from the member i bought it from, unfortunately it will seem that i have to splice into it anyway and not use the oem plug.
To me 1cm does not look right as
Looks a little more to me
hey was here trying 2 find out where i can find the connector 2 the fender lights that go under the z emblem on the fender. im going crazy here nd been looking for months. if you or anyone can help please do so. thank you
Old 06-03-2015, 12:16 PM
  #60
Zhu Tou
Zhu Tou's Avatar
I'd really like to do this.
Does anyone know if these (on JDM models):
1) Blink "together" with the turn signals?
2) Blink "opposite" with the turn signals?
3) Are solid (remain on with the driving lights)?
Thanks!
Quick Reply: JDM Fender Sidemarker Install
