Sponsored by:
Sponsored by:
Suede Headliner {Pics}
Old 02-23-2010, 08:05 AM
  #41
JasonZ-YA
JasonZ-YA's Avatar
^ lol...
-J
Old 02-23-2010, 06:05 PM
  #42
aaronz8
aaronz8's Avatar
so you guys just glued the suede on top of the existing cloth on the headliner?
Old 02-23-2010, 06:45 PM
  #43
dkmesa350z
dkmesa350z's Avatar
Yep, I was skeptical but it worked like a charm.
Old 02-23-2010, 07:12 PM
  #44
*ICE*
*ICE*'s Avatar
yea 3M Super 90 make everything stick together like magic!
Old 02-23-2010, 07:24 PM
  #45
aaronz8
aaronz8's Avatar
noiceee i'm gonna do it this weekend
Old 02-23-2010, 08:31 PM
  #46
labelworkshop75
labelworkshop75's Avatar
I thought I remembered hearing about some suede fabric that was easily stretched to make the install easier on another members headliner thread. Was this "butter suede" easy to work with. I really want to do this but want to make sure I have the right supplies before I go attempting this.
Also, what did you guys do for the visor safety sticker part? just paint over it? scrape it off then paint? leave the sticker alone and paint around?
Old 02-23-2010, 08:49 PM
  #47
xthejokerx
xthejokerx's Avatar
I'm not feeling the suede headliner... It just looks very cheap... Maybe it's just personal preference? I'm trying very hard to like it... Maybe one day I will, but regardless, nice job on the craftsmanship
Old 02-23-2010, 10:12 PM
  #48
Royal_T
Royal_T's Avatar
^^ I was the same like you until I saw it in person... and BAM now I have it done..
Old 02-24-2010, 02:47 AM
  #49
maXmood
Under Boost!
maXmood's Avatar
very nice OP....
Old 02-24-2010, 03:35 AM
  #50
dkmesa350z
dkmesa350z's Avatar
Originally Posted by labelworkshop75
I thought I remembered hearing about some suede fabric that was easily stretched to make the install easier on another members headliner thread. Was this "buttermilk suede" easy to work with. I really want to do this but want to make sure I have the right supplies before I go attempting this.
It is not stretchy at all, but it was still easy to work with. I have decided against wrapping the visor and will just use fabric paint. I plan to paint right over the warning sticker.
Old 02-24-2010, 07:22 AM
  #51
labelworkshop75
In this members thread https://my350z.com/forum/exterior-an...-threw-up.html he explains that it is very important to choose a fabric that is easily stretchable as so it leaves no creases or any other flaws while wrapping. You say this fabric you used was easy to work with, without being stretchable? Just wanna make sure I get this right the first time
Old 02-24-2010, 07:26 AM
  #52
zrzly?
zrzly?'s Avatar
buttersuede isn't elastic or anything, but it's got just the right amount of give to it, I use it whenever I wrap anything, and so far everything's held up just fine. just don't oversaturate with the glue, and make sure it goes perfectly into corners/creases and bends. If it doesn't, after everything "cures", those pieces will start to lift up and you'll have to re do the whole thing.
Old 02-24-2010, 07:38 AM
  #53
*ICE*
*ICE*'s Avatar
so spray the OEM headliner, edges, curves and the underside with glue, then apply the fabric?
Old 02-24-2010, 07:50 AM
  #54
dkmesa350z
dkmesa350z's Avatar
I sprayed the center 1/3rd of the headliner with glue, applied and smoothed the material. Then sprayed each side 1/3rd one at a time and did the same thing. Then I flipped it over and applied glue to secure the edges to the back.
I agree with be careful not to oversaturate the glue. When I was testing the material out before applying it to the headliner, I used too much glue and the results are pretty ugly and messy. You will know if you have sprayed too much, if it is wet enough to run on the surface, it is definitely too much.
That's right, the material barely gives...as you can see from the pics, it yielded no creases.
Old 02-25-2010, 10:27 AM
  #55
labelworkshop75
cool sounds like its buttersuede and just not too much 3M. First center 1/3 then work your way to the side of the headliner. Thanks
Old 02-25-2010, 03:33 PM
  #56
dkmesa350z
dkmesa350z's Avatar
you got it. Good luck!
Old 02-25-2010, 08:14 PM
  #57
labelworkshop75
Originally Posted by Royal_T
Yea its the vinyl/fabric paint that you get from autozone... Make sure you us like 5 coats on the visors so they are nice and black. and remove every plastic..
Here is a pic of every thing laid out,, my camera made the suede fabric look purple... but its black just like the visors.
what was the name of the material you used? was it from hancock fabrics?
Old 02-26-2010, 09:23 AM
  #58
jewfood
jewfood's Avatar
Default not buttersuede
i just ordered 2 yards off the buttersuede off of hancockfabrics and was kinda disappointed when i got it. it looked cheap and nothing like what the OP used. so i went back to the website to realized it not the buttersuede that i wanted so i pretty much got . links are posted below so no one else makes the same mistake i did.
Butter Suede Black Fabric 5.99/yd
http://www.hancockfabrics.com/Butter...VVviewprod.htm
Solid Black Plush Suede Fabric 11.99/yd
http://www.hancockfabrics.com/Solid-...VVviewprod.htm
Old 02-26-2010, 09:28 AM
  #59
350zfan1
350zfan1's Avatar
Looks ever so sweet , is that the rear pillars and front a pillars wrapd also..?
How much a professional interior shop would charge to do this and the amount of time it would take.
Old 02-26-2010, 09:38 AM
  #60
deezz
deezz's Avatar
I went to a fabrics store here in Dayton and realized the same thing. Most of the fake suede looks like crap.
Quick Reply: Suede Headliner {Pics}
