Blackout Emblems, any pic's?
#43
I would remove it. I mean you're only supposed to do the emblem right and that part is the paint.
But my question is how would we remove it? Cause when I do mine tomo it's gonna be exactly the same for me as well. What's the best way of removing the plasticdip from there?
#47
I was thinking of leaving like you did, but I think from far on our silver cars especially it'll look like a black blob! So prolly good you removed it, I will too. How exactly you did you remove it, cause I am really worried about that part? Don't want to ruin the paint on the emblems while removing them.
Haha plastidip stuff is addicting!
I even masked my door handles but I don't think I am going to do them for the same reason you said. lol
Plus they seem to much harder, I mean if we just do the outside from the side you can see silver inside you know? Unless you try to spray inside or something too? But i think it might look weird with just black on the side with you being able to see the silver under them from the side.
#49
on
Yea im actually having problems with the "350z" emblem. The edges won't come out clean. Everything else was perfect, just this last emblem is giving me problems. Any tips? The plasti dip should just be coming off smooth and in tact, but instead its leaving little pieces around the edges which leaves me to pick them away, unfortunately some spots will pick away some of the plasti dip on the actual emblem. Resulting hid bulbs in a re-do. What did everyone use to pick away at the edges?
#50
on
Yeah i'm debating this too. Plasti dip plus clear bra. I don't know. Seems like color match paint and clearcoat is probably a better option - for me at least. I have to replace my driver side handle due to bubbling anyway.
#53
I messed mine up. When removing the masking area, it kept pulling stuff from the emblem as well. I tried to be careful but then it kept pulling it anyway and showing silver underneath it, I got pissed off and ripped it all up. Then it took me ages trying to get all the paint **** off from the edges and corners and it's still not completely off.
Which brings me to the questions, is it possible to remove the badges, front and back and then use the plastidip to paint them, let them dry and then put them back up? That would be much cleaner wouldn't it? If so can someone show me some instructions as to how to remove the rear nissan badge and front and then put them back up?
#54
#57
Where can I buy that 3M stuff? Removing is easy I can just use goo gone and a fishing line. I did that the first time when I debadged the 350Z part. But I need the tape that I can use to re-attch the emblem. Would that be available from Canadian Tire or something? What exactly is it called? I can search online.
Also doesnt the real emblem has holes or something ender it? Or is it the front one? I remember reading back then that it did. Can it still work with that?
#58
You can order the tape through ebay or amazon or call a local bodyshop.
#60
Would any of these tape work to put the emblem back on?
http://www.canadiantire.ca/AST/brows....jsp?locale=en
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
http://www.homehardware.ca/Products/..._2sided_5_8x36
http://www.homehardware.ca/Products/...ting_19mmx1_5m
I think the last one seems like the best option?
Or if not can you show me the link of what tape you're talking about? I can just order it online then.
