Sponsored by:
Sponsored by:
Custom interior material options.
Old 09-13-2012, 09:21 PM
Marrocco350z
Marrocco350z's Avatar
I just bought some of this...
Amazon Amazon
Old 09-14-2012, 05:40 AM
BCB
BCB's Avatar
BMCCAN, where did you get that CF centerpiece for the dash?
Do you guys think a high grade vinyl would look cheap if using for the same purpose?
Old 09-14-2012, 09:56 AM
TPete19
TPete19's Avatar
read thru this.
Youre not going to get a good result w suede on a detailed piece w moving parts like the center console and lid, ill tell you that right off the bat.
you dont have room for material in the gaps.
its too bulky.. try it, youll see what i mean.
Not exactly true. You can get good results with suede on moving parts like the cubby door. You'll just need to plan for the extra material and shave down your parts accordingly. My cubby door works better than it did before I wrapped it since I also took the time to shave the latch in order to make the action smoother.
Originally Posted by Marrocco350z
That's the right stuff. Metro restyling is where a lot of us get that vinyl. You can order straight through there website to get rid of the ebay middleman. This 3M scotchprint is what I used in the pic below.
Also, you're going to want to hunt down some 3M primer 94 to make sure the vinyl holds. With the complex curves, especially on the shift-surround, the adhesive backing won't hold on its own for long.
Old 12-21-2013, 11:24 AM
04SilverBulletZ
04SilverBulletZ's Avatar
TPete19 - If you don't mind my asking, how did you shave your cubby door?
I'm having my center console and ac/ auto shifter areas wrapped in fabric material today and hoping fitment won't be too much of a PITA, since I'm doing install myself to help save money. I don't know what the materials called but it's not thin like scotchprint vinyl that self adheres bc I have some of that; which I will be using on the nav button.
Anyways..I have the stock nav/stock sterio and was thinking those eight corners are going to be the hardest parts for fitment. The guy doing it said he's done a few 350s center console and they had no problems but it was def a tight fit. Just to be safe I told him not to wrap the cubby door, just incase its too tight and cant lift.
What do you think??
Old 12-22-2013, 01:41 PM
04SilverBulletZ
Fitment was perfect after shaving everthing down.
I forgot to put the stupid silver gauge rings back on but it looks better without, or maybe I'll paint them black and put them back on
Old 12-23-2013, 06:18 PM
Raulie
Raulie's Avatar
04SilverBulletZ - Do you know where can I buy that material? Right now, I'm sanding the whole console, and I was going to paint it, but now I'm not sure after seeing your results...
Old 12-23-2013, 08:34 PM
04SilverBulletZ
I had this local guy do it, like 20min from where I live. He had me hand pick the material from his warehouse but I don't recall the actual name or anything but he has a whole roll of it..
Sonnys Custom Auto Interiors
Stanton, CA
Tel # 714-826-8935
Ask him you want the same material as the kid who came in Saturday with the two center consol pieces for the 350z. His english is a little rough, so if you know it use spanish. Think his name was Marcos.
Hope this helps! If not you can always pick your own online!
Also if you do this, just remember to shave or have someone shave about 1/8-1/16" on the insides of the three circular ac ****. If you do the actual cubby door in material you'll have to shave that on all four sides as well, think I'll have that done in a few weeks...
3vilbunny
07-18-2017 05:10 PM
HoBrahYouStink
06-24-2016 10:58 PM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: Custom interior material options.
