Sponsored by:
Sponsored by:
driver side window gets stuck
Old 08-20-2014, 08:42 PM
03Lemans350z
03Lemans350z's Avatar
Default driver side window gets stuck
My window worked fine for as long as I had the car. Just the normal half way roll down problem that I don't really mind. But one night my window didn't go up all the way. It goes up fast until about 1/4 the way up and the window struggles to roll up and quits on me like there's something holding it down. I just don't know if it's the motor dying or if there's something in the way that could stop it from rolling up?
Old 08-21-2014, 02:25 AM
SQuaLZ
SQuaLZ's Avatar
Motor is probably dying. Common problem on the Z. Had to change mine last year on my 08. Now my drivers side window is much faster than my passenger side. Will eventually have to change that side also.
Old 08-21-2014, 05:41 AM
Syner
Syner's Avatar
definitely the motor. there is nothing that could "get in the way"
Old 08-22-2014, 07:50 AM
03Lemans350z
That's what I was thinking too. I doubt there could be anything in the way. I heard the regulators were problems too. I guess I'll just bring it to a dealer. Should probably be like $125 to fix.
Old 08-22-2014, 08:05 AM
Syner
Syner's Avatar
lol not from a dealer it won't be.
just order a new motor online and do it yourself. even if you aren't experienced, it shouldn't take more than an hour.
Old 08-22-2014, 08:45 AM
SQuaLZ
SQuaLZ's Avatar
Dealer tried charging me $700 to change mine. After some issues with my warranty they ended up doing the job for free, I just had to pay for the parts.
Old 08-22-2014, 08:58 AM
ksuberk54
ksuberk54's Avatar
Mine does this when it gets hot outside. I just hold it until it gets to the top and it works fine. When its not hot I obviously don't have this problem.
Old 08-22-2014, 10:12 PM
03Lemans350z
So I went to the dealer today and they wanted 500 for the repair and diagnostic. I can fix it myself no problem but idk if it's the motor or regulator that's broken
Old 08-23-2014, 03:24 AM
SQuaLZ
SQuaLZ's Avatar
For mine Inhad them change both. I think it was around $250 in parts.
Old 08-23-2014, 06:02 AM
samsniss350z
samsniss350z's Avatar
A pound to a pinch of **** your motor is toast! If your car (judging by your forum name) is an '03 it's done really well to have lasted eleven years. Have you tried the window reset? If so and its still not working then you have a few choices.
1) You take it to a stealer and get raped so you walk bandy for a while.
2) You buy a motor and fit it yourself. There are YouTube videos to help you out.
3) You remove the motor strip it and fit new brushes. Someone (can't remember who) has catalogue numbers (search is your friend) and it seems that these are the cause of the motor failure. There is a caveat to this method though and that is, there is no guarantee as to how long this fix will last.
4) Take it to an Independent Auto Electrician and let him sort it out.
Old 08-23-2014, 07:05 AM
Syner
Syner's Avatar
Because I'm nice:
http://www.courtesyparts.com/kb_sear...14_715_846_855
Old 08-30-2014, 11:18 AM
03Lemans350z
Got a new motor for 130 and now the window works fine. It was actually way easier to replace than I thought.
Old 09-22-2014, 10:59 PM
03Lemans350z
So the same thing happened again on the same window. I think it's the regulator that needs to be replaced. But it worked fine for the month i had it on. What do you guys think?
Old 09-23-2014, 03:42 AM
SQuaLZ
SQuaLZ's Avatar
Yes typically when you change the motor you should change the regulator as well, since you already have everything open it makes sense. Hopefully lesson learned. They should cover that motor and give you a new one.
Old 09-23-2014, 04:57 AM
travlee
Master
travlee's Avatar
Received 9,045 Likes on 6,511 Posts
my drivers is starting to act up, my extended warranty covers it but i just need to find time to get it to the stealership
lapham3
10-07-2022 03:15 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
04-04-2016 07:52 AM
samansharif
09-25-2015 12:31 PM
Quick Reply: driver side window gets stuck
