Water Underneath Rug ? Pics inside ! Attention !
So pretty much after it rains my rug underneath my driver side Matt gets very damp.today I decided to pull up the rug and check it out.after I pulled up the white Styrofoam filler, it was very damp, wet and disgusting under there.I can't seem to find where our how the water is getting threw to there any ideas?btw the white cloth insulation near the pedals are completely dry.
Yes I do drive in the rain.Where are these under plugs located because I thoroughly checked or at least I thought I did my floor Pan when I lifted the rug? Unless you can't see the plugs from inside the car due to being covered by the sound deadening glue or something? Also about that weather stripping, the carpet area along the door or should I say closest to the door never seems to be wet? Thanks again guys I just really don't want mildew or rust to form.
There is at least one plug right in the hole/dip area where you are getting the water. It is under your sound deadening though. I wonder if the sound deadening is coming up a little and the plug is damaged, allowing some water to seep in during rain driving.
The plug(s) is/are not rubber. It's a hard plastic. I cracked mine when I chipped away the sound deadening. Since your deadener is still there, you would have to remove it to get to the plug. I would suggest sealing it from the bottom/outside. Maybe some underbody spray would seal it up. If that is where you're getting water of course.
As for the seals, I would check whatever seals you can see.
Will maybe Jack up my car tonight when i get home to take a look thanks again for the replies fellas
You can see the damaged plug in the pic. I sealed and painted over it. And you can see there are two other small spots where I sealed and painted over a few inches from the main one. I think those were also from the factory, but it could have just been where I chiseled through the floor and had to seal it up. It's been a while so I don't remember for sure. That should give you an idea on where to look underneath.
on
That looks like pee damage
you could prob. also dry everything and use a water hose and just spray the area around the door and see if it get's wet again. if it's getting wet you know that your door seals are gone....if it's not it most def. coming from somewhere else.
not sure if it's just the pic, but it looks like the water is coming from behind the white foam!?!?!?!
Hardest Setting
on
Keep an eye on this, I drove in heavy rain a couple times, and my car was brand new. never knew about the seals cracking/giving away. My interior harness got damaged due to this, I initially blamed bad wiring from a head unit install but I've found water in connectors underneath the covers in the engine bay, and what you pictured above leading me to believe it might be water from the start.
HOW !?!
To the point my harness rusted i.e. the slimy green corrosion covered the whole harness...causing several bugs to slowly kill the car !
keep us posted on what you plan to do...I put electrical gel on most of my engine bay connections and will block off holes as mentioned above.
HOW !?!
on
HOW !?!
HOW !?!
Where is this harness located? I'm going through the same issues with electrical gremlins. Car beeping, instrumentation turning off and on, warning beeps, courtesy done light staying half lit.
FYI. I had my windshield replaced and in the process found that the drivers side weatherstripping shrunk. The top rear corner had a gap in it under the a pillar. Dealer wants $125 for the piece and its coming from LA or NJ.
The leak caused water to puddle behind the drivers side floor. This was while the car was parked.
Hardest Setting
on
The picture below is the interior harness which control many of the functions i.e. dome light/trunk/horn etc
Also something to check is the BCM located by the dead pedal. Which the interior harness is connected to.
350Z_Al
10-29-2020 07:44 PM
