My z looking sexy, what you think?
#142
350Z/370Z Tech Moderator
Probably not a worry as any hub centric spacers over 15mm come with studs and mount over the originals with the wheels bolting to the spacer studs.
#143
https://www.ecstuning.com/Search/Sit...cer/ES2855872/
I have never seen a spacer with studs in it?
#144
I have 20mm spacers on the front of my Z4 no studs on them at all they slide over the existing studs which I lengthened. How would you bolt the spacer on with out interfering with the back side of the wheel? I have had every thing from 5mm to 20mm and have adjusted the stud or lug bolt length accordingly. mine are hub centric.
terrasmak (01-26-2016)
#147
EDIT: I stand corrected 4 grand will buy the wheels but not the tires too
http://www.tirerack.com/wheels/Wheel...3&autoModClar=
#148
I've never been a proponent of spacers either; however, after running one pair on each of my cars progressively harder on hills runs (for proper fitment of high offset - should say, "not low enough" - wheels/tires), haven't experienced any problems and have gone back to re-check torque as well.... not needed. Still prefer not to run them but so far, they work just fine.
#149
I agred on tinting tails. I'm in a small black car and don't need some dude texting in a Denali to be my latest bumper sticker. Same reason I did DRLs.
I'm in healthcare and have to treat the roadkill the EMTs bring in. Broken pelvis and femurs last forever.
Function> Style.
Function> Style.
travlee (01-25-2016)
#151
OP, you could run three feet of spacers with a 275-90-17 tire and the wheels would still look like crap. 17's don't work on Z's. Stop trying to make everyone else happy and set your car up the way you enjoy it, but please kill it with fire if you are keeping these wheels. Where are the $4.6k BBS? I guess just $4.6k of BS
#152
Car looks more lifted than my buddy's jeep with 35's. And why do you have a Nismo plate on the car? It's not a Nismo, you live in PA and we don't need front plates. Never understood putting a Chevy plate on a Silverado? Can you not remember what kind of car you have or do you think the other badging on the car is lying to you?
Syner (01-26-2016)
Heritage
10-30-2015 10:44 AM
alove112
Wheels Tires
10-30-2015 10:20 AM
IMPORTIMAGE
10-29-2015 08:52 AM
