Sponsored by:
Sponsored by:
Cheaper upgrade hatch struts
Old 11-19-2015, 12:10 PM
Underscore_Hero
Underscore_Hero's Avatar
Default Cheaper upgrade hatch struts
Just got these from Lift Supports Depot via Amazon.
Saved some money and they work great.
Original struts couldn't hold the hatch up after the Nismo V1 wing install.
Old 11-19-2015, 12:44 PM
iideadeyeii
iideadeyeii's Avatar
I grabbed mine off ebay for under $30 a few years ago I believe and they still are working fine...that hatch is super heavy without them
I'm assuming shipping would be a lot because of your location so amazon is great for that
Old 11-19-2015, 12:47 PM
Underscore_Hero
Mine was $64.60 total ($18 shipping).
I got it cause it was still cheaper than Z1 and Concept Z. Z1 shipping was $40 for a $70 order, concept z was $25 shipping for a $70 order. Not worth it imho.
Old 11-19-2015, 04:16 PM
jv350z
jv350z's Avatar
Gotta get me some of that!
Old 11-20-2015, 12:00 AM
dcains
dcains's Avatar
I bought a set of Strong Arm supports from Amazon maybe 3 years ago, and they're still working great. IIRC, they were ~$50, but I get free shipping with Amazon Prime.
Old 11-29-2015, 09:27 AM
IIQuickSilverII
IIQuickSilverII's Avatar
did you have any alignment/offset issues with the hatch when closed?
Old 11-29-2015, 09:46 AM
nizmo_0385
nizmo_0385's Avatar
Do you guys know if the 07 08 nismo uses beefier struts? Mine are gurgling when i open it
Old 11-29-2015, 10:07 AM
dcains
dcains's Avatar
You will if you install the bottom mounts upside-down.
Old 11-29-2015, 10:08 AM
dcains
dcains's Avatar
Check the part numbers on courtesyparts.com
Old 11-29-2015, 10:20 AM
nizmo_0385
nizmo_0385's Avatar
Will that tell me if theyre beefier though?
Old 11-29-2015, 03:48 PM
MatthewBouchard
MatthewBouchard's Avatar
I purchased a set through amazon about 6 months ago. Atm they are creaky/very loud and also have issues now with a stillen spoiler installed. Ordering the Z1 HP set, with he BF sale.
Guess I got a very cheap set?
Old 11-29-2015, 04:12 PM
travlee
Master
travlee's Avatar
Received 9,045 Likes on 6,511 Posts
350zhatchshocksandmore.com
forum member here that is engineer...
Old 12-01-2015, 06:31 PM
RWDBajan
RWDBajan's Avatar
Still trying to figure out how someone could do that. Change them one side at a time, and use the other side to verify. Ain't rocket science.
Old 12-01-2015, 06:34 PM
travlee
Master
travlee's Avatar
what you did makes perfect sense, but i guarantee that some will take both sides off at the same time and then not know how they go back on
Old 12-01-2015, 06:56 PM
Underscore_Hero
No alignment issues as long as you install the bottom mount correctly, bolt holes should be the highest point of the mount (follow the body line), not the nub.
Only issue was premature surface rust on the bolts. I suggest coating them with silicone after install. Didnt help that my car sat in the rain during storm season.
Old 12-01-2015, 07:10 PM
IIQuickSilverII
Can you post a few pics... Mini write up?
Old 12-01-2015, 07:24 PM
Underscore_Hero
Honestly super simple.
Here's the install guide:
Only thing it doesn't show are the locking clips, just remove with a small flathead or pliers. Then reinstall them after you mount the struts.
Old 11-07-2023, 07:17 AM
jim9bob
jim9bob's Avatar
Some brands don't include brackets. Can the oem struts be removed so replacements can be installed? Do the oem struts have locking clips to be removed and replaced? I didn't see them on my 2005.
Old 11-07-2023, 07:20 AM
jim9bob
jim9bob's Avatar
Among brands of replacement struts ranging from about $20 to $90 per pair are these:
Henkeyi
AiYiu
Tuff Support
Lift Supports Depot
TadaMark
Vepagoo
Z1
Boxi
Sachs
Strongarm
Stabilus
FCS
AMS Automotive
TRW.
Who has used any of these, and what's the recommendation? Thanks.
Old 11-07-2023, 09:16 AM
DarkZ03
DarkZ03's Avatar
Just get Z1.
NZMOWND
01-09-2015 02:03 PM
Sickboy101
08-25-2013 10:51 PM
geddy lee
Mid-Atlantic
06-12-2009 12:14 PM
Stillen Z
04-25-2009 02:10 PM
350Mark
05-24-2008 11:04 PM
Quick Reply: Cheaper upgrade hatch struts
