Sponsored by:
Sponsored by:
350z cabin noise, road noise and leakage.
Old 04-30-2016, 06:29 AM
terrj
terrj's Avatar
Default 350z cabin noise, road noise and leakage.
Im not sure if this is common but my i have an 03 Track model and the noise is pretty bad. Also i took it for a wash and both windows were leaking and it never had happened before.
Anybody got any tips on how i can reduce the noise and how to stop the leak ?
Old 04-30-2016, 07:22 AM
travlee
Master
travlee's Avatar
Received 9,043 Likes on 6,509 Posts
you can dynomat the rear, doors, and floor if you want to pull everything out.
for the leaking window, is it coming from the top? if so you may need to replace the weather seal
http://www.courtesyparts.com/nissan/...=upper-w-strip
Old 04-30-2016, 10:57 AM
terrj
terrj's Avatar
Can i do it myself or do i need to bring the car to a specialize shop for this ?
Old 04-30-2016, 12:58 PM
travlee
Master
travlee's Avatar
For the dyno mat, you can do it yourself
Old 05-01-2016, 05:42 PM
terrj
terrj's Avatar
Sorry to annoy you but is there a thread on it ? And where can i purchase dynomat ? What kind do i need ??? Im a noob at this
Old 05-01-2016, 05:45 PM
travlee
Master
travlee's Avatar
you have to pull everything up, rub down with alcohol, lay it on... heat it up some, then use roller to get it flat and on all the curves
http://www.ebay.com/sch/i.html?_from...dener&_sacat=0
Old 05-02-2016, 04:53 PM
terrj
terrj's Avatar
Thanks man, this project is gonna be a ***** to finish
Old 05-02-2016, 04:55 PM
travlee
Master
travlee's Avatar
only if you let it.... the sound deadening is easy, harbor freight heat gun, gloves (several pair), a roller, a buddy, and beer you can get it knocked out
Old 05-02-2016, 05:41 PM
Spike100
Spike100's Avatar
I consider disassembly and reassembly as the most difficult part of a sound deadening project.
I really think that most of the noise comes in from the wheel wells. Station wagons (with their rear tires inside the car) are noisy, and the Z coupe is a miniature station wagon. Notice that the Infinity G-series coupe has much less noise than the Nissan z-series cars. That is because the Infinity G-series has a trunk and its rear wheels outside the car.
The next big “noise source” after the wheel wells is the porous floor (lots of holes) in the rear compartment and the compartment-filled divider behind the seats.
Old 05-02-2016, 07:52 PM
terrj
terrj's Avatar
The hardest part is i dont know where to start and how much material im going to need haha
Old 05-02-2016, 07:55 PM
terrj
terrj's Avatar
Im probably gonna try to spray the wheel wells instead of trying to glue the mat. Dont think its going to last with the mat...
Old 05-03-2016, 02:53 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Nothing like adding weight on to the track edition, if your worried about road noise you should have gotten a different car.
Old 05-03-2016, 07:00 AM
terrj
terrj's Avatar
Holy ****, sorry for not being a track purist. I came from a G35, this was my first 350z and fyi bro, if u have nothing constructive to add then keep your mouth shut, ****in sound stupid as hell. **** load of people have done this mod, are you going to tell them to get a different car too ?
Old 05-03-2016, 08:57 AM
dboyzalter
dboyzalter's Avatar
If you dont want opinions and off topic non constructive criticism why dont you use the search function and stop making useless threads that have been covered over and over again...
I just figured by your dumb questions that talking you out of adding sound deadening mat would be the most helpful.
Old 05-03-2016, 09:02 AM
dboyzalter
dboyzalter's Avatar
but I sound stupid
Old 05-03-2016, 02:40 PM
terrj
terrj's Avatar
but I sound stupid
Are you for real ? I cant ask questions if im not sure about it ? Did you join the forum already knowing everything or did you have to start countless threads also ? Like i said if you dont have anything nice to say then **** off, nobody's forcing to answer to my thread.
Old 05-03-2016, 04:01 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Let's both chill out here.
Go to the car audio section, you will find a lot more info on matting there.
Old 05-03-2016, 04:27 PM
e30cabrio
e30cabrio's Avatar
Received 2,578 Likes on 2,037 Posts
Can't we all get along?
Old 05-03-2016, 05:34 PM
Spike100
Spike100's Avatar
We have not had a detailed discussion about sound deadening for some time now. I think we can revisit this issue. Truthfully I’ve tried doing some sound deadening and have not been fully pleased with the results. That is why I am interested in someone else taking a new shot at this.
I hope that terrj undertakes a new sound deadening project. And if he chooses doing that, I hope he provides information and pictures of his progress and project.
Old 05-03-2016, 05:38 PM
travlee
Master
travlee's Avatar
i did a layer, 2 in some sections of the hatch area..... was it worth it, yeah quieted it down some, but due to my exhaust it was hard... would i do it again, nope
Quick Reply: 350z cabin noise, road noise and leakage.
