Can I use normal 194 LED bulbs in my parking lights?
on
Before I got through the hastle of getting to the parking lights in my Z I have a question. I've read about the LED bulbs from Ares for the parking lights and I wonder what makes them different than say a normal 194/168 LED bulb? Does the Z take a special fitment bulb? From what I've read they are just regular 194/168 bulbs used for the parking lights but I could be wrong. Will any 194 bulb fit in this location or just what? Any info would be helpful.
on
Any 194 bulb will fit in this slot, whether its LED or halogen, the 194 is the slot fitting. 194 bulbs are I think the most commonly used bulb throughout all manufactuers. On the Z alone they are the parking, license plate, and cargo area lights. I also use them on my trailer, and my truck. What Ares is offering is a light that fits in the 194 fitting but a brighter LED to give it a better appearance.
That sound about right to the rest of you guys, please feel free to correct any mistake I may have made.
ZRiCaN
ZRiCaN
ZRiCaN
ZRiCaN
on
The reason I ask is...I can't understand why people pay $30 or whatever it is for LED bulbs in the 194 size. I'm sure his product is great but...I use $5 LED bulbs with 6 LEDs per bulb in my Maxima and it seems to get the job done. I just figured that the Z had some sort of different design in the bulb socket or something.
Here is a picture of my Maxima. Unless I'm mistaken I dont see how Ares bulbs could be much brigher than these.
Victor
on
I think you can alter them to draw the same load as a normal incadescent bulb (as Ares has successfully done), but it might be kind of hard to do if you don't know what you are doing.
Hey Hamy, those parking lights look darn bright, where'd you get them?
BTW...very clean looking Maxima
on
I got my bulbs from Superlumination. They sell a great product. The ones in that picture are 5 LEDs...he makes the whole way up to 9 LED bulbs to fit the 194 socket. Not to mention the price is very good.
on
Originally posted by dkny_boi
ah.. that's too bad I was hoping they might work fine without adding in the load resistors. I wanna get a set for my brake lights, there shouldn't be any problems would there?
they look nice, matches the 3rd brake light nicely. (i mean it turns on and off just as fast, no delay like a regular bulb.)
on
How many LED's are you using for your brake lights?
Are you using the ones from autolumination?
Thanks,
Thanks,
Originally posted by mgl
i have leds in my brake lights and have not had any problems.
on
Thanks,
Thanks,
i got the bulbs from superlumination.com
on
Thanks, they sell 9, 12 & 15 LED in the 7443 (dual filament) format.
I will send them an e-mail to see if the 15 LED light is any larger than a normal 7443 light.
I wonder if there is any difference between red and clear LEDs once they are behind the red tail light housing.
i think it was a 9led or 12led bulb in red. not sure, i would have to go see in order to be sure. i know that if you get too many leds, the bulb won't fit into the hole in the back of the taillight.
on
I have the 15 LED turn signals for the fronts. They fit fine in the housing fine, but I had to "persuade" the bulb into the connection. I had to add a resistor to stop the hyper flashing. I got the resistor in Ebay for $7 each. I like them a lot. They are mostly clear, so there is not yellow reflection. When they're on you can see the distinct forward facing lights and the side lights within the bulb assembly light most of the housing.
I also have the "Non-Ares" 194 white LEDS for the parking lights. I think that they are bright enough and I hardly ever just use the parking lights.
on
Could you also tell me if it's a similar shade of red as with the original bulbs, or deeper... not as bright...
maxpowers, if you could... post what they tell you about the size of the 15led bulb compared to regular bulb? I'm curious about the red led or white led too... another site that sold led bulbs recommended the use of red leds even if it's behind a red lense... i was thinking that because the light is much more blue looking than a regular bulb, the colour might look weird w/ a white led behind the red lense
on
So the bulbs you bought from superlumination had to be persuaded? As in modified to fit?
Do you actually have to add a resistor or whatever to it? Did you have to solder it on?
What a hassle...
By "most of the housing" being lit, do you mean that it's hard to see the bulb flash from the side of the car?
on
That's exactly why i wanted the led bulbs for my taillights
i honestly don't think its as bright. a little deeper red, IMO. but its definitely still visible.
