Feedback & Suggestions for Our Forum This is NOT a place to ask car/modification questions!
For posting feedback, suggestions or comments regarding our My350Z.com forum.
***HAVING TROUBLE? Can't Access My350z from Work/Home? ***
Old 01-31-2007, 03:25 PM
Wired 24/7
Dr. Wired
Wired 24/7's Avatar
Default ***HAVING TROUBLE? Can't Access My350z from Work/Home? ***
Some users (myself included) are having difficulty accessing my350z from work even though the site works at home.
Or vice versa, perhaps you can access at work but NOT at home.
Here is the ***FIX*** for windows users
Go to c:\windows\system32\drivers\etc\
open HOSTS file using notepad
add the following 2 lines to the bottom of the file, underneath 127.0.0.1 and localhost
67.201.16.205 www.my350z.com
67.201.16.205 my350z.com
then save, exit, and reboot your machine. It should be able to access my350z.com again!!!
Edit: had to change IP address since Internet Brands took over
Old 01-31-2007, 03:50 PM
___DJK___
___DJK___'s Avatar
^^ True haxor at work!
Old 01-31-2007, 03:56 PM
Demon Z
Demon Z's Avatar
Worked like a charm. Well done!
P.S.- Don't ever let that sh*t happen again. Those other sites, with all due respect, were Go-bots to My350Z's Transformers. Sure, they're similar and have the same objective, but they just ain't the same!!!!
Old 01-31-2007, 04:53 PM
___DJK___
___DJK___'s Avatar
Originally Posted by MC
this wont work for me. im running vista now and it wont let me save the notepad file when i open it
Looks like your gonna have to roll back to XP
Old 01-31-2007, 05:36 PM
DavesZ#3
DavesZ#3's Avatar
The file may be Readonly. A lot of virus protection, anti-spyware and similar programs will set things like that to RO to keep them from being hijacked. Windows may deliver it that way too.
Old 01-31-2007, 05:40 PM
35ounces
03 CS Track 6MT
35ounces's Avatar
Also you can put it all on one line like this:
69.80.198.27 my350z.com www.my350z.com
Old 01-31-2007, 05:43 PM
98sr20ve
98sr20ve's Avatar
This solved all my problems. I could get onto the forum using a backdoor, but I would get kicked off in certian sections of the forum. Problem gone. Thanks.
Old 01-31-2007, 06:03 PM
Velicos
Velicos's Avatar
#1 - This should not be considered a **FIX**. Modifying the hosts record should be a temporary band aid until the name servers / domain issue is taken care of and the DNS updates can propagate throughout the net.
#2 - What in the **** happened? Why wasn't the domain re-newed?
#3 - For Vista users, if you want to modify your host record.... follow these following instructions:
Originally Posted by OpenSourceApress.com
hosts file, which resides at C:\Windows\System32\drivers\etc. However, it’s no longer possible to just open notepad and change the file; you need to do so under the root privilege, much like is done using sudo on Linux.
The process is actually quite similar to that described in the previous entry. Just navigate to Start -> Programs -> Accessories -> Notepad, right click and select Run as administrator.
Once opened, navigate to the hosts file, make your changes, and you’ll be able to save without issue.
Good luck getting the domain functional...... I cried when I saw DirectNIC's placeholder instead of my morning forced induction reading material.... /sniff
Old 01-31-2007, 06:54 PM
98sr20ve
98sr20ve's Avatar
So should I undue the fix in a couple days?
Old 01-31-2007, 07:08 PM
GodZilla
Bad Mojo
GodZilla's Avatar
1) Yes only a temp fix until the DNS updates
2) Well you know when you set something up on an Automatic renewal and the little CC experation date is expired, well that was one thing. The second was the admin email for the domain records wasn't working at the time.
3) ...
I agree it was pretty messed up, and trust me it was just as much of a pain for us as it was for you.
Old 01-31-2007, 07:13 PM
05-Z
05-Z's Avatar
I bet....it's all good.
Very rarely are there issues, my online bank account has a worse record.
Old 01-31-2007, 07:19 PM
Armitage
Armitage's Avatar
It worked for me going to www.my370z.com or the IP provided. The lady can't get in at all though.
Old 01-31-2007, 07:28 PM
Jay'Z
Jay'Z's Avatar
I have had the worst three days of my life because of this!!!!!!!
Old 01-31-2007, 07:38 PM
Spike100
Spike100's Avatar
Ouch… Are you kidding me? The advice is to hack into a site?
If it’s all volunteer labor… I accept the problem and it’s an explanation.
But.. if anyone’s getting paid to do this… You’re Fired!
--Spike
Edit: For clarity: This msg. was not meant for others posting here. It is directed to the Administrators and Moderators.
Old 01-31-2007, 10:17 PM
yobri
yobri's Avatar
Helped him edit the file in Vista.
Old 01-31-2007, 10:28 PM
GTNPU Z
VERTEX Army CEO
GTNPU Z's Avatar
^ So how are you liking Vista?
Old 01-31-2007, 10:35 PM
GTNPU Z
VERTEX Army CEO
GTNPU Z's Avatar
^ Me likes!
Quick Reply: ***HAVING TROUBLE? Can't Access My350z from Work/Home? ***
