How to do Twins right the first time!!!
#63
on
thanks for the info.
FYI: I sent them an email and here's their reply:
Thomas Hornig <mrtomcat@llss.com> wrote:
Hi there
I am about to get a APS TT kit for my 2005 350Z , as part of this I want to upgrade my internals. I was referred to you via my350z.com
I am thinking of getting the Basic Short Block and have two questions:
Basic short block: $2700 + $1000 core
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
Shot peened stock rods
ARP Rod Studs
New Rod and Main bearings w/ceramic coating
CP Pistons .020 over(8.5:1 or 11.5:1)
1) Once I order how long will it take until I receive the short block and
2) I am planning to tune to around 600 whp will the this block manage this or will I need to get the upgraded block?
thanks
Answer:
We always reccomend getting rods for anything over 450 RWHP.....As of right now we do not have any cores to sell. If you send us your block it will be about 4 weeks, depending on the availability of the pistons....
Mark
Hi there
Block redecked
Crank balanced
ARP Rod Studs
thanks
Answer:
Mark
#65
on
Originally Posted by nis350ztt
They refund you $2000, not $1000.
#66
Forged Internals.com
Originally Posted by thawk408
Actually, they do both. For most of the shortblocks it is $1000 and then for most of the longblocks it is $2000.
#69
Originally Posted by Leo14
So how much whp would the sgp ultimate short block max out at???
#71
on
Long Block??
~650, after that, you'll need new sleeves. Plus some headwork.
Thanks. What about the long block. Can you put that on the 350z? If so, would that be any more benefitial than a short block?
Thanks Again,
Leo
#72
Thanks Again,
Leo
Thanks Again,
Leo
#73
on
Cutouts on test pipes !!
I had them already and now that I'm adding the Greddy system doesn't it make since that if they are open (tune it that way) that HP and torque would increase over not opening them. Dynoing while N/A or using n2o did not show a gain either way. Reading up on turbos leads me to believe you want to do away with back pressure as much as possible. Any thoughts??
#74
builtZmotors
builtZmotors
on
#75
on
Fi ???
Okay i'm kinda new to the Z world but from what i have seen maybe with the TT kits but i have seen and know a few guys running on stock motors with added blowers and have been running them for almost 1 year now no problems maybe it depends on what level you want to be at ???
#76
on
Just a tip, when you're getting the TT install done, make sure to move the power steering line away from the turbo.I had a custom made steel line.
The stock aluminum line kept rubbing on the turbo and made a hole, I had no power steering and I had to bring it back to the shop. I wasn't charged for the repair but it's still an inconveniece.
#77
on
stock aluminum line
Thank You!
Cesar
#78
on
Originally Posted by CESAROTORRES
Does this apply also to APS TT kit?
Thank You!
Cesar
Thank You!
Cesar
I'm not sure as the turbos aren't the same size.You might want to tell the installer to make a note of this.
Tasso-
