Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Forced Induction
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Closed Thread
Thread Tools Search this Thread
Old 04-21-2006, 03:32 PM   #121
nissansource
nissansource's Avatar
Points: 3,001, Level: 33
Points: 3,001, Level: 33 Points: 3,001, Level: 33 Points: 3,001, Level: 33
Today's Activity: 1.7%
Today's Activity: 1.7% Today's Activity: 1.7% Today's Activity: 1.7%
Send a message via AIM to nissansource
Damn wondering on the dyno and debating which car to bring to speedventures, Shags NX2k or My TNz will they alow an enclosed trailer at the track?!?!? with sleeping area? store my z and myself inside
__________________
Special Thanks to the companies that sponsored the car www.Turboneticsinc.com SS 350z www.deatschwerks.com 650cc, Audio Kenwood, Suspension Megan,Sways Hotchkis, Wheels 19" mesh, Exhaust ApexI N1 style,OEM Nismo bodykit,2006 Nissan Pathfinder:BONESTOCK TOWCAR-GONE Now H3 Hummer, 350z Sold for Corvette Z06 Sold for House, Silver 350z Nismo V2 Car DD
nissansource is offline
Old 04-21-2006, 03:34 PM   #122
RageWoRX
Well as far as the fuel pump/injector issues ....
I'm assuming that they are at least running a Walbro GSS340 255L/hr High Pressure Pump (Walbro's highest output pump or it was anyway) with probly some upgraded wiring (I hope) for the pump harness seeing as most stock pump wiring can exhibit up to a 25% drop in fuel pump volume because of losses in the cheap wiring.
From what I can gather they are running some sort of an FMU (not sure what A/F ratio its at) in combination with some sort of Voltage Boost A Pump system (can increase the fuel pump capacity up to 50% the Cobra guys love them .) Which might actually be one contained unit. So with the BAP adding any where from 1%-50% (usally 50% is pushing it) to the capacity of the Walbro it is theoretically possible for that single pump to flow more fuel for increased whp than it could before the BAP system. Now is it really a great idea to push the Walbro that hard .... who knows I probly wouldn't do it but alot of the 03-04 Cobra guys spraying big shots (150 shot+ plus running almost 20 psi of boost) swear by thier BAP systems since they can make thier stock pump/pumps flow more than most aftermarket setups.
Now the injectors .... there is always the good old forumla The square root of (new pressure/old pressure) * stock flow rate.. Since they said they aren't using 1000cc injectors to achieve thier 800+ whp I would assume they are increasing the pressure to compensate for the smaller size of thier injectors to supply enough fuel for thier goals (again this depends on the size they are actually using that would dictate the need for added pressure if any ... but it has to be 700cc + at least).
an example:
At 80 psi (a 1.46 ratio) of pressure you can theorectically make a 382cc out of a rated 260cc injector ....... or a 750cc into a theoretical 1095cc. Now I don't know if they are running as high as 80 psi so I don't know the actual numbers in thier case.
However at around 90psi Walbros have been know to fail and at around 100psi injector lockup can occur sometimes even sooner.
So again would I do these things ... probly not but they have been done for some time now as these are not new concepts. They are ways of getting increased potential from a fuel system but at the same time they stress all the components more so than a system that is "over built" for the Power goals so yeah its a risk I don't care who you are. True your Fuel Pump isn't always maxed out and only has to flow at such a high rate for short bursts .. but again it can sometimes get iffy .... its the what if factor and its increased 10 fold.
Sooo ... I'm not even really sure this is what they are doing with their "Top Secret" fuel setup but logic whould lead me to believe at least some of my guesses are true in thier case. Mabey some of the VRT boys can help me with that one. I like some others have many more questions about this setup so I guess we will just have to wait for the article
I am also a bit skeptical of the results that were posted .... but in truth I would love for them to be true and I'm not nessiarly saying they aren't.
In the end if what they are doing (or any other shop for that matter) provides the community with more valuable R&D than its all good .
-Jon
RageWoRX is offline
Old 04-21-2006, 03:42 PM   #123
faster than u
faster than u's Avatar
can some one put this on street fire so i can see im going crazy and want to see this
__________________
12.662 @110.84 100 shot
pop charger, JIC y-pipe, AAM single ti,test pipes,
stance coilovers
www.TAMPARACING.com
faster than u is offline
Old 04-21-2006, 07:22 PM   #124
350Zzzz
Professional
350Zzzz's Avatar
Points: 3,568, Level: 37
Points: 3,568, Level: 37 Points: 3,568, Level: 37 Points: 3,568, Level: 37
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Quote:
Originally Posted by mraturbo
THANKS PHILTHY. At least when we say we make huge power WE HAVE A CAR, DYNO, and VIDEO THAT AT LEAST EXIST....
Appreciate your feedback. As mentioned, Sports Compact is doing an article so we will let them tell the entire story. Show up at Spring Mountain Raceway and I will be happy for you to drive the car.
HATING OR NOT HATING...All good. We have been hated on since day one...NOTHING NEW...Everyone scratching their heads saying blah blah blah...Cussing, your this sucks, your videos suck, your whatever...Thanks for the confidence. We are still having fun. And for absolute certain, it is a daily driven car. What do you think I do????? - have my 800 WHP motor with crazy fuel system and swap it with my 500 WHP motor when I want to drive the streets? No simply, when I am driving at 500 WHP, I turn the boost controller OFF.
To repeat,
It is a 3.5-liter VQ35 - Not a 3.8 or a 4.3, or a V8 or whatever...
No Sleeves
Stock fuel rail with larger injectors
Walbro pump in stock location
JWT FMU (boost fuel pressure regulator)
No fuel return
Split Second - Same as in JWT kit
Piping - Same as in the standard JWT kit
Using Garret GT28R ball bearing (called BB700) turbos - the BB530s are used in the JWT standard kit.
Modified JWT kit (only changed manifolds. I added the sinlge SFR/Spearco intercooler-not for power yet because I have a single opening front end -The JWT G35 intercoolers would be fine for this and any application)
See you at the track.
M
Michael,
Are you saying that this stock VQ35DE does not use sleeves how is that possible, short of recasting a newly designed block? Or did Nissan come up with a new block design for the 350Z? Can't wait to see how that is done.
Wow that's amazing
G
350Zzzz is offline
Old 04-21-2006, 07:57 PM   #125
chimmike
chimmike's Avatar
Send a message via AIM to chimmike
he's saying it's a stock 350z block with pistons and rods, there are no aftermarket sleeves installed.
lol.
__________________
RIP: Lakelandkev 6/17/2007 ... You will be missedmoforeynolds-----I just troll for chicks on the Planned Parenthood forums. Not always the hottest, but you know they put out. Sluts.
chimmike is offline
Old 04-21-2006, 08:26 PM   #126
theking
theking's Avatar
Points: 3,116, Level: 34
Points: 3,116, Level: 34 Points: 3,116, Level: 34 Points: 3,116, Level: 34
BAP + Walbro = Fun Times(but dangerous) His numbers are very believable. With huge BAP voltages(aka Split Second) this can be done on one single Walbro. I have a brother-in-law with an 03 Cobra to prove it(I still shake my head when he tells me what he's running since two Focus SVT pumps fit right into his stock housing).
__________________
2004 CBR 1000RR My other ride has 30mm, 2.75 Rockets and Hellfires.
theking is offline
Old 04-21-2006, 08:48 PM   #127
solidsnake
solidsnake's Avatar
Points: 6,892, Level: 54
Points: 6,892, Level: 54 Points: 6,892, Level: 54 Points: 6,892, Level: 54
Send a message via AIM to solidsnake
Someone Help Me View This!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!
solidsnake is offline
Old 04-21-2006, 11:35 PM   #128
mchapman
Quote:
Originally Posted by RnRRacing
Michael, I think all of the Internet would love some videos of your VRT 800hp G35 vs. RnR 800hp EVO. I think it would make for some great entertainment for sure. We could do some highways pulls so it would be more even then going from a stop.
What a great idea!
mchapman is offline
Old 04-22-2006, 03:49 PM   #129
Julian@MRC
Julian@MRC's Avatar
Send a message via AIM to Julian@MRC
Subscribing for interest...
Philthy, you are in central Jersey? Drop me a line one day, I would love to see what you have going on..
Julian@MRC is offline
Old 04-23-2006, 07:27 AM   #130
backagain
backagain's Avatar
Send a message via AIM to backagain
Quote:
__________________
2003 350z/Vortech SC/400 HP/342 wheel TQ www.panhandlez.com
backagain is offline
Old 04-23-2006, 09:04 AM   #131
failsafe306
failsafe306's Avatar
Points: 5,888, Level: 49
Points: 5,888, Level: 49 Points: 5,888, Level: 49 Points: 5,888, Level: 49
Today's Activity: 2.1%
Today's Activity: 2.1% Today's Activity: 2.1% Today's Activity: 2.1%
Send a message via AIM to failsafe306
pimpin fo fo's........
Just curious, and I might have missed this somewhere, but what exhaust are you running?
__________________
2008 Nogaro Red
failsafe306 is offline
Old 04-23-2006, 02:55 PM   #132
SBT
Points: 2,836, Level: 32
Points: 2,836, Level: 32 Points: 2,836, Level: 32 Points: 2,836, Level: 32
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Send a message via AIM to SBT
http://videos.streetfire.net/search/...9C733A2BC5.htm
i dont understand why people care about looking at a speedometer on a dyno
can't you set the resistance anyway?
not to say it doesn't look cool, if anything
SBT is offline
Old 04-23-2006, 04:08 PM   #133
G352NV
I think I read in another post hes running a stock exhaust.
G352NV is offline
Old 04-23-2006, 04:53 PM   #134
bacalhau16
bacalhau16's Avatar
Points: 3,292, Level: 35
Points: 3,292, Level: 35 Points: 3,292, Level: 35 Points: 3,292, Level: 35
what an awesome thread. I understand some people's not believing in all. but im sure all questions will be answered once the article is out!
bacalhau16 is offline
Old 04-23-2006, 05:16 PM   #135
rkd350z
rkd350z's Avatar
Points: 3,048, Level: 33
Points: 3,048, Level: 33 Points: 3,048, Level: 33 Points: 3,048, Level: 33
Today's Activity: 5.9%
Today's Activity: 5.9% Today's Activity: 5.9% Today's Activity: 5.9%
Amazed
rkd350z is offline
Old 04-23-2006, 05:51 PM   #136
Julian@MRC
Julian@MRC's Avatar
Quote:
Not even close to being possible on a stock exhaust..I would think he needs a minimum of a 3" exhaust to flow enough air for 800hp.
Old 04-23-2006, 07:02 PM   #137
bacalhau16
bacalhau16's Avatar
there was a post about switching an injen ses to the vrt 3" and it gained a lot of hp and torque with a new tune on a customers car.
i dont think any of these numbers would be possible with a stock exhaust.
Old 04-23-2006, 07:09 PM   #138
SinCity350Z
Track Whore
SinCity350Z's Avatar
Send a message via AIM to SinCity350Z
That was my car. The exhaust wasn't a VRT exhaust but the SVRTechnologies 3" dual. The names are close, but they are two completely different companies. The switch and re-tune gained 20 something whp and 72wtq.
I may be wrong, but I think that Mr.A's G still has the stock exhaust. At least it did last I heard. I should have looked yesterday at the track.
__________________
2003 Nissan 350Z Time Attack Car
2009 Nissan 370Z
SinCity350Z is offline
Old 04-23-2006, 11:25 PM   #139
aalzuhair
aalzuhair's Avatar
Points: 4,117, Level: 40
Points: 4,117, Level: 40 Points: 4,117, Level: 40 Points: 4,117, Level: 40
Send a message via AIM to aalzuhair
Quote:
with a cut-out after the down pipe, I think he can
aalzuhair is offline
Old 04-24-2006, 05:30 AM   #140
Julian@MRC
Julian@MRC's Avatar
Quote:
Thats not a stock exhaust..
My350Z
350 Z
Paid Advertisement
Closed Thread
Tags
600hp, 800, 800whp, armani, fmu, g35, jwt, monster, pipe, rageworx, suit, vrt, vrtjwt, whp, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Scott Bush & Relentless Autosports: Exposing the Hype, Lies, and Failure Mike Wazowski Forced Induction 5437 03-14-2011 04:38 AM
Best turbo kit out of Greddy/JWT/ and TN? jtgli Forced Induction 104 06-29-2006 10:26 AM
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
