Turbo kit ratings
on
Turbo kit ratings
With all these kits out now, I was just interested as to what kits were rated for what HP ranges. For example, the JWT TT kit is made for a more conservative boost based around the stock engine. So I guess what i'm trying to figure out is something like:
JWT TT
Capable of making - ????? HP
APS TT
Greddy TT
and so on and so on. I guess we can hypothetically throw in the idea of having a built engine. (This is not limited to TT's, ST can also be throw into the mix)
JWT TT
APS TT
Greddy TT
Finally some go
JWT TT
APS TT
Greddy TT
JWT TT
APS TT
Greddy TT
on
Hmmmmmm i see, I guess I didn't take that into consideration. But I was just basing it on the turbo kit alone. Since if I were to shorten it down to psi level, size of injectors etc. etc. It would make things much more difficult since no 2 people run the exact setup. Hmmm lets see what others have to say.
on
In case you haven't seen it. It's a decent starting point for comparisons.
http://www.nissansportmag.com/shooto...oshootout.html
on
I have the jwt kit my buddy has the greddy kit and rode in both i have seen the aps tt but ever rode in one before there all good set ups you cant go wrong with any but all are diffrent. my power is down low the gred is mid- high power and feels strong aps??? the JWT kit feels stock though but with a boost almost adding a v8 in or cars nothing crazy just real smooth power.
Forged Performance
Forged Performance
All things being equal...
Greddy TT 600-650whp
APS TT 550-600whp
JWT TT 500-550whp
APS TT Extreme: 700-750whp
PE TT: 525-500whp
Turbonetics Single T: 450whp
APS Single T: 450-475whp
As alluded to....this simply means that the turbocharger is capable of flowing a volume of air...that would produce these numbers. Doesnt mean you will actually achieve these numbers, without significant upgrades.
APS TT 550-600whp
JWT TT 500-550whp
PE TT: 525-500whp
on
APS TT 550-600whp
JWT TT 500-550whp
PE TT: 525-500whp
APS TT 550-600whp
JWT TT 500-550whp
PE TT: 525-500whp
on
Originally Posted by E***zzzzy
I did a TN install out of the box with TN reflash with everything else stock that did 377 HP
Forged Performance
Forged Performance
Originally Posted by ht4
I thought there were a few people well over 600whp on regular (non-extreme) aps twin turbos.
I was conservative with the numbers, becuase power output can change with mods, fuel, and tuning. In theory, the airflow power numbers I posted are pretty close...but individual tunes and installs can generate more or less power than I posted.
Originally Posted by SaadSindhu
^Correct me if im wrong but i was under the impression that the aps extreme can put down 800whp with a comlpete array of supporting mods like fueling, build, heads, etc..??
Turbo Whore
on
1 Post
Originally Posted by WA2GOOD
You may also add the VRT/JWT 700BB TT kit, It puts 600-800whp down.
When do we get to see an independent dyno of that setup? I'd like to see what that setup puts down on something other than JWT's dyno.
Performance Nissan
Performance Nissan
on
Turbo Whore
on
1 Post
Originally Posted by Ken@Performance
It was at the Stillen meet and it put something like 6XX in low boost I believe.
I was more talking about the 800whp on a single fuel pump claim. Plenty of people have broken 600whp.
Originally Posted by FrickU
Sure did, They wouldn't let him do the six gear pull because it was exeeding the dyno speed limit
Forged Performance
Forged Performance
Only time will tell..so for now..I am being a little conservative with my estimate. I also hope everyone realizes that anything about 600-700whp (depending on the dyno used), is going to require race fuels.
Turbo Whore
on
1 Post
APS claim is 50lb/min worth of airflow, which is theoretically enough for 1000 crank hp, and roughly 800whp.
You mean fuelflow right?
