brake boosting a TT 350z. - Page 2 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 11-20-2006, 05:14 AM   #21
Sharif@Forged
Forged Performance
Sharif@Forged's Avatar
Phunk, if you still want to keep your brake lights functional, you might try doing this instead.
If you unplug the VDC harness behind your ABS junction box near your brake resevior, you can brake boost. If you plan to wire up a switch, I would do it here, and just kill power to that module with the switch. This way, you can break boost, and still keep your break lights functional for the street. Your speedo is killed, but who cares.
And damn...break boosting from a roll is really really fun!
Sharif@Forged is offline   Reply With Quote
Old 11-20-2006, 05:15 AM   #22
TheCajunStyle
TheCajunStyle's Avatar
OK guys, this topic seems a little too noob for people for who have post counts in the thousands. (just playing!)
Get your head under the dash...Look under the fulcrum point for the brake pedal...You'll see a little switch that is activated when you press the brake...You need to tap in to the wire (the one that goes to the ECU). Install a switch. Boom bang done.
The TCS lights do not come on for me...
TheCajunStyle is offline   Reply With Quote
Old 11-20-2006, 05:59 AM   #23
MI 35th
OGPremierMafia
MI 35th's Avatar
We all get a lil newb sometimes!
bBrake boosting is such a great advantage when street racing and is damn fun as well.
MI 35th is offline   Reply With Quote
Old 11-20-2006, 06:32 AM   #24
bverschage
bverschage's Avatar
Interesting
bverschage is offline   Reply With Quote
Old 11-20-2006, 06:50 AM   #25
Sharif@Forged
Forged Performance
But driving around on the street without brake lights is kind dangerous...and cops frown up that...LOL.
But either method will work.
Old 11-20-2006, 09:02 AM   #26
phunk
CJ Motorsports
phunk's Avatar
Sharif, the method I said about just disabling that single pin at the ECU would not turn off the brake lights. Its the cleanest method as in it eliminates only one single thing, and thats the stoplamp signal to the ECU... therefore everything is still functional 100% except the gas will not close under braking now.
But I am glad to hear it works out for you the way you did it, part of me just wanted to hear that when someone disabled the system they have been able to do it. Just motivates me to actually go do it now.
phunk is offline   Reply With Quote
Old 11-20-2006, 09:11 AM   #27
redman333
redman333's Avatar
Can you post pics of this and where its at, I'm intersted in trying this myself. Now I know why I couldn't brake boost on the street. When I tried it NA I just thought it wasn't enough power. Now I'm FI and still couldn't so I figured it was something like this.
redman333 is offline   Reply With Quote
Old 11-20-2006, 09:18 AM   #28
tig488
well do it and quit talking about it, and let us know how it goes, since youre off from work.
tig488 is offline   Reply With Quote
Old 11-20-2006, 10:20 AM   #29
phunk
CJ Motorsports
phunk's Avatar
Quote:
the jerk store called....
Old 11-20-2006, 10:40 AM   #30
doug
Quote:
of course you couldn't brake boost when you were N/A .. you can't build boost with no form of Forced Induction to begin with.
doug is offline   Reply With Quote
Old 11-20-2006, 11:20 AM   #31
tig488
LOL! youre still at the computer? get to work!
Old 11-20-2006, 01:53 PM   #32
Sharif@Forged
Forged Performance
Ah....so it just eliminates the stop lamp signal TO the ECU. Very clever.
Old 11-20-2006, 04:27 PM   #33
down_shift
Brake boosting ftw. It's sooo much fun on the highway
down_shift is offline   Reply With Quote
Old 11-20-2006, 07:25 PM   #34
rcdash
rcdash's Avatar
Per the service manual that pin (101) is supposed to go down to 0V at the ECU when the brake pedal is released. You *may* want to tie the ECU side of that signal to a ground (chassis) to make sure it doesn't "float". (If you get a CEL - it'd be a remedy).
It'd be great if the VDC switch could be used to disable both at the same time - anyone know where in the service manual is the wiring for the VDC switch (is it on/off vs. momentary push)?
EDIT: I found it in the BRC.pdf section of the manual (for a 2004 G35 coupe) - looks like it'd be pretty straightforward with one relay from the VDC off switch (connector M9) triggering a relay that connects the ECU pin 101 to either the sensor or ground.
rcdash is offline   Reply With Quote
Old 11-23-2006, 01:57 AM   #35
taurran
taurran's Avatar
Any updates on this? I'm very interested in hearing your suggestions.
I played around with it tonight and no luck.
taurran is offline   Reply With Quote
Old 11-23-2006, 02:02 AM   #36
phunk
CJ Motorsports
phunk's Avatar
no updates from here, havent felt like climbing around the mess of FCON wiring in my car.
However, if you were to put a toggle switch on pin 101 of your ECU, i will almost guarentee you that you will be able to brake boost no problem when you open the circuit
Old 11-23-2006, 02:05 AM   #37
taurran
taurran's Avatar
I might have to try that one of these weekends (after the holiday). I was hoping someone else would have feedback soon and I wouldn't have to play guinea pig on it. Also, I'm running out of places to hide all these gauges and switches.
Old 11-23-2006, 05:48 AM   #38
n/a
n/a's Avatar
Sorry guys,
I understand what is being discussed but a little lost with the term 'Brake Boosting'. Could someone explain why this term is used?
n/a is offline   Reply With Quote
Old 11-23-2006, 07:17 AM   #39
QuadCam
QuadCam's Avatar
I haven't heard that term either, but I'm pretty sure it is the technique of spooling the turbo up while cruising. then, you can let off the brake and instantly be at full boost. You are just creating a load for the engine/turbos to work against to get the turbos spooling.
QuadCam is offline   Reply With Quote
Old 11-23-2006, 08:55 AM   #40
Sharif@Forged
Forged Performance
Dammit...ok..I will try it. It's a lot easier than popping my hood, and fiddling around my engine bay. People will think I am reconnecting my NOS......sweet!
Thread Thread Starter Forum Replies Last Post
Autocross Brake Pads hajwoj Autocross/Road 27 11-01-2015 05:25 PM
Replacing Tail light issue. 350z82 Exterior & Interior 19 10-01-2015 06:25 PM
Tags
2005, boost, brake, constant, g35, g37, infiniti, infinity, lights, sensor, slip, snow, stay, switch, toggle, vdc, yaw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
