brake boosting a TT 350z. - Page 8 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 06-08-2007, 10:46 AM   #141
rcdash
rcdash's Avatar
You could do it yourself, but it'll be a lot easier once KP has his modules ready to go... Hopefully sflg will report back soon.
rcdash is offline   Reply With Quote
Old 06-08-2007, 10:48 AM   #142
35ounces
03 CS Track 6MT
35ounces's Avatar
Quote:
Originally Posted by KPierson
When the module is installed properly you won't get any codes, so it won't disable cruise control. I simply wanted to see what would happen if you cut the wire completely (SES and no cruise).
Other then that, this mod only allows you to brake torque and brake boost. It won't disable VDC at all, so if you 'cut' the wire to the YAW sensor you may still want to do that, although I've never had a problem simply hitting the VDC Off button.
KEWL! Make me one.
35ounces is offline   Reply With Quote
Old 06-08-2007, 11:25 AM   #143
MardiGrasMax
MardiGrasMax's Avatar
Quote:
Originally Posted by doug
Matt.. what is that sig all about? you said you wern't going to mod the G
"Hi, My name is Matt, and I'm a horsepower-aholic"
Its an addiction!
MardiGrasMax is offline   Reply With Quote
Old 06-08-2007, 12:20 PM   #144
taurran
taurran's Avatar
I'll be running one of these as soon as it's done, which would be cool because I WILL have my car back by the end of next month.
taurran is offline   Reply With Quote
Old 06-08-2007, 04:57 PM   #145
35ounces
03 CS Track 6MT
35ounces's Avatar
Well post a new thread up and tell us what you're doing already Craig.
Kevin let me know when you have one for me.
Old 06-08-2007, 05:19 PM   #146
KPierson
If anyone wants to 'test' one of these modules for $25 shipped (paypal) send me a PM by the end of this weekend.
The first five payments will be honored, if more then 5 people send payment.
As of now, they haven't been tested to work on the AT trannys, but I have brake boosted with success on my '04 6mt.
KPierson is offline   Reply With Quote
Old 06-08-2007, 05:35 PM   #147
Gilley
Gilley's Avatar
Oh hell, another KP Tech module to buy!!
Would this be beneficial on a Vortech 6mt?
Gilley is offline   Reply With Quote
Old 06-08-2007, 05:38 PM   #148
KPierson
Since S/Cers are RPM based the 'brake boost' would't be beneficial. If you have an at (like you do) then you 'may' be able to 'brake torque' launch, IF you can get traction.
Old 06-08-2007, 06:41 PM   #149
doug
so how does the connection of the module work? splicing? connected to? i probably missed it earlier in the thread
doug is offline   Reply With Quote
Old 06-08-2007, 07:38 PM   #150
Gilley
Gilley's Avatar
I see. It sounds like fun.
Maybe Ron would like one of these on his TT Z.
My 6mt coupe is the vortec car though. The 5at sedan is the NA beater.
Old 06-08-2007, 07:46 PM   #151
kostat26
kostat26's Avatar
im very intrested. its been so long and no1 has a video of this being done...
kostat26 is offline   Reply With Quote
Old 06-10-2007, 04:08 PM   #152
KPierson
You have to cut the 'brake' wire going to the ECU. You run the input in to the module, and then the module has an output that hooks to the other side. You then need switched power and ground - I grabbed them at the ECU and mounted the box in the passenger kick panel. You could grab it off the 12power outlet if it is close in the Z (I have a G). There are only four wires on it total.
Old 06-10-2007, 04:17 PM   #153
doug
thanks for the info.. if it works great.. i would definatley grab one too
Old 06-10-2007, 10:49 PM   #154
denchan350gt
denchan350gt's Avatar
Do you have pics of the box installed and exactly which wires were used? I have a 04 G also so it should hook up the same as yours.
Hopefully it will work with a 5AT, money has been sent for a module.
I'll post before and after vids when I get it installed after I get my car back in a week or two.
denchan350gt is offline   Reply With Quote
Old 06-11-2007, 01:52 AM   #155
KPierson
I could take some pictures, but I would highly recomend verifying all wiring with a voltage meter. There are over 100 wires at the ECU, and multiple wires of the same color. The only way to be 100% sure that you have the right wire is to electronically verify it. I'll try to snap some pictures tonight.
Old 06-11-2007, 09:24 AM   #156
Alberto
Cranky FI Owner
Alberto's Avatar
KPierson-clean your inbox out! Im trying to send you a message...
Alberto is offline   Reply With Quote
Old 06-11-2007, 01:55 PM   #157
KPierson
Sorry about that, its clear.
Old 06-11-2007, 05:45 PM   #158
KPierson
Here are a couple pictures of the wire that was cut. The wire in my '04 G35 coupe is pink/blue. Ignore the extra green and blue wires, they are for VVT, not this project.
Here is a quick movie of how the ECU reads the brake switch. Basically, there are two brake switches (1 and 2). 1 is on the left, and is used for Cruise Control and brake lights. 2 is on the right of the screen and is used by the ECU to prevent throttle and braking at the same time. You can see when I push the pedal both of them switch to 'depressed', but about 1 second later the right signal goes back to 'normal'. This movie, admittingly, isn't very impressive and is a somewhat big file, so unless you really want to see how it works I wouldn't waste the time downloading it!
http://www.kptechnologies.com/images/brakeboost.avi (5 megs)
Old 06-11-2007, 07:13 PM   #159
QuadCam
QuadCam's Avatar
PM sent.
BTW, will this also allow you to do a burnout at the track?
QuadCam is offline   Reply With Quote
Old 06-11-2007, 07:25 PM   #160
KPierson
It should, but it hasn't been confirmed yet.
Thread Thread Starter Forum Replies Last Post
Autocross Brake Pads hajwoj Autocross/Road 27 11-01-2015 05:25 PM
Replacing Tail light issue. 350z82 Exterior & Interior 19 10-01-2015 06:25 PM
Tags
2005, boost, brake, constant, g35, g37, infiniti, infinity, lights, sensor, slip, snow, stay, switch, toggle, vdc, yaw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
