Alcohol/Methanol/Water Injection Q&A...
Old 04-17-2007, 10:07 PM
Devil Z
Devil Z's Avatar
Originally Posted by Triji
Devil, I just noticed you have the Zeitronix as well... Love that wideband
Yeah man I swear to god it's more accurate than my Defi gauges (which I barely even look at while driving).
Old 04-17-2007, 10:20 PM
Ultimate CC
Ultimate CC's Avatar
yea its a sweat wideband, one of the best for sure...
Old 04-17-2007, 10:24 PM
Triji
Triji's Avatar
Originally Posted by Ultimate CC
basically the unit sends a 12v signal when a drop in flow is detected, this signal can be interpreted to lower boost, lower timing, change maps etc, whatever what you wire it, when your ready let me know and I can help devise a way for you to hook it up with your SC...
Ok Cool, So... I could set it up to switch maps on the Utec if it sends a 12v signal... That would be cool... I could go from the meth map to my 96 oct map and stay safe
Damn.... My car is starting to sound like a meth head
Old 04-18-2007, 05:02 AM
Ultimate CC
that you could, its a pretty sweet setup...your car is going to need AA meetings after you introduce it to meth
Old 04-18-2007, 08:16 AM
NS_350GT
NS_350GT's Avatar
Im actually looking into the same kit as Triji right now, would be running it with the 3.12. I also have a Utec sitting at home right now. Did you say that you could hook up the snow performance kit to the utec and let the utec control it?
Old 04-18-2007, 10:05 AM
Ultimate CC
I am 99% sure you can, i know on my evo i had it controled in the sense that it turned it on and off...but the 350z has better firmware
Old 04-18-2007, 10:57 AM
Kenk2
Professional
Kenk2's Avatar
Hey bro...
WHen you want someone to tune the UTEC, let me know.. I will be up there on Sat morning to see Codys monster if you want to talk more..
Back on topic.. If I wanted to mix my own meth/ water, what is it that I use? Denatured Alcohol or ??
THanks
Old 04-18-2007, 11:32 AM
akcraig85
akcraig85's Avatar
what kind of alch, meth do you use? is it easy to buy and how expensive?
Old 04-18-2007, 11:39 AM
NS_350GT
NS_350GT's Avatar
+1
Old 04-18-2007, 11:49 AM
bbs350z
bbs350z's Avatar
interested as well. debating on throwing this on the evo, since i just tossed in a 50 trim.
Old 04-18-2007, 12:38 PM
Triji
Triji's Avatar
This is what I am useing as soon as I get my kit here... I just ordered my kit yesterday. I will be taking pix of my install for a DIY guide as well.
http://www.snowperformance.net/product.php?pk=3
It should not take more than 2 hours to install from the instructions I looked at.
Old 04-18-2007, 12:51 PM
NS_350GT
NS_350GT's Avatar
Ahh yes. The "BOOST JUICE" Im anxious now to see how yours goes. Still pretty sure im getting a kit.
Old 04-18-2007, 03:03 PM
Ultimate CC
You would want to find pure methanol (aka heet at walmart) which can be found for between 3-8 dollars a gallon typically at various stores and shops and drag strips...even farms have it to make biodiesel...and mix that with distilled water...
Old 04-18-2007, 09:05 PM
bbs350z
bbs350z's Avatar
^^it has 2 b a perfect 50/50 mixture if i remember correctly.
Old 04-18-2007, 09:33 PM
Ultimate CC
if its a little off your afrs will be a little off, shouldn't be an issue unless your tuned on the ragged edge...your afrs change with the weather...if your concerned about getting it perfect buy a hydrometer and test it...i have one that I keep at the shop so i can ensure i make up perfect %...
Old 05-14-2007, 06:00 PM
DMK
DMK's Avatar
I am debating on whether to get this or not. I am planning on upgrading to the 2.87 pulley and with my list of mods, I should be over 400whp. With any type of injection, I know I have the ability to pull more power out of the motor and be just as safe as a lower hp tune. But, since 400+whp is already considered risky for a stock block, I don't think I would tune it for more power. Therefore, I would probably only run water/alky and not meth. Does a supercharged car really need injection? If I ran 100% meth, how much more power would I be able to get out of of it, if my stock tune was 400whp?
Also, there are several different combinations of fluid injection. Can someone list the pro's and con's of each?
Straight Water
Water / Alcohol
Alcohol / Meth
Straight Meth
Old 08-19-2007, 05:43 PM
Ultimate CC
its not always about power with injection, its about making power safely, your motor will likely last much longer even on a conservative 400whp as you will get virtually zero knock whereas with no injection you are likely to come into issues with knock especially on those hot summer days...
Old 08-19-2007, 06:27 PM
  #38
THE ROADSTER
THE ROADSTER's Avatar
is Aquamist a good system ? it's going in my car.
Old 08-19-2007, 06:38 PM
  #39
Ultimate CC
to be completely honest, most kits out today are very good, hard to really buy a bad kit but that doesn't mean there isn't kits that are better bangs for your buck but aquamist certainly make great kits, im very biased to snow performance since I am a dealer for them but i have nothing against a aquamist if you have the money for one...
Old 08-20-2007, 06:05 AM
  #40
350zDCalb
builtZmotors
350zDCalb's Avatar
\\I'm not not an expert on all the kits, but I know that aquamist is one of the most expensive, and to my knowledge, has the most elaborate control to keep the water/fuel ratio consistant,... it receives a pulse rate signal from a fuel injector and pulsed water in at a similar rate... not just a water hose dumping water in the intake...
I run an aquamist, love it
Quick Reply: Alcohol/Methanol/Water Injection Q&A...
