Alcohol/Methanol/Water Injection Q&A...
#81
on
Originally Posted by reptile718
I have a question. My stillen s/c kit has a locked SS box which runs a 7th injector that is necessary for the kit to function correctly. I would have to upgrade my six injectors and eliminate the 7th if I want to run a different EMS. I am interested in water/meth injection but don't want to do whats listed above. Is there a way I can run this kit correctly without changing my tune since my SS box wont let me change any settings? The s/c makes gobs of heat and just for the cooling purposes alone would make it completely worth it.
#82
on
Originally Posted by Ultimate CC
the problem with it is that it varies in percent of meth in most areas due to the changing weather and its rare to have some more than 35% meth so its mainly water...with mainly water you will make way less whp and you can also run better odds of getting cylinder wash than when running higher meth...
#85
on
with meth you have to get a tune, theres really no way around that, sorry
#86
on
That sucks, what if I just run straight water for cooling purposes would I still need to tune?
#88
on
Originally Posted by DMK
Nope. You can tune for water to get some more power out of it, but adding it to an already safe/good tune is the best way, IMO. Just some more piece of mind that you engine is less likely to blow.
#89
on
#90
I just purchased this stage 1 kit (link at bottom) , i dont want my tune to rely on water/meth so I am just going to run it ontop of my current tune. What do you make of this kit does it look okay?
Also, I have heard of many people using windshield washer fluid, but I have heard there is soap in it. Is that a safe route or should I just mix 50% water and 50% meth.
Or... should I just use straight water? I just want it for safety, as I said before, dont want to be dependent on it. Does it matter if the water is distilled or is tap water fine?
Thanks for the help!
http://www.alcoholinjectionsystems.c...c37/index.html
#91
on
#93
on
Use distilled water only. The minerals in the tap water will mess with the engine. Water is your best choice as it provides the most amount of safety and you do not need a tune for it. If you add meth to your current tune, you will probably lose power because it will run rich. You are basically adding more fuel with meth/alky.
#94
on
Ok, I have a few questions. It says that Water/Meth reduce Air Temp by 50+ deg, is it the Water that does that? So in the middle of the Summer Session where temp goes 90+, will having just water help you keep/maintain your power since you will not be that affected of the Heat?
I'm also looking to get this but my main purpose is for safety and also help me on the Hot Summer Days.
#95
on
#98
on
Originally Posted by mok5
I'm currently running a different EMS (FCON IS) with my stage 4. Was having so much problem with my SS box. I was planning/hoping to try to run an water/meth with my setup. would i have to ditch my 7th injector to get this to work??
Any suggestions on how to run this on a Stillen kit with a 7th injector and tunable?
#99
on
Well I am not super familar with this 7th injector setup, if you have a link to some info on it that would help greatly...but are you planning on using meth injection as your 7th or do you want to just add it and basically have 8 injectors because you can certainly do either as long as you get the car tuned...in the evos we push 400whp on meth and stock turbo which is beyond stock 580 injectors but on meth it gives you plenty of room and keeps idc down to 70% from nearly 100%...
#100
on
I was planning on running it as a 8th injector. Although i wasn't sure were to locate the spray nozzel since the 7th injector is located on the lower portion of the aluminun inlet on the back of the supercharger. Ideally I would guess the location of the 7th injector would be the place to locate the spray nozzel. Where else can you locate it?
