Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Forced Induction
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
ZCON 09 9/28/09 - 10/2/09 (Z Car Convention San Antonio, TX)
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 06-27-2007, 03:42 PM   #1
GurgenPB
UltimateSleeper
My Garage
GurgenPB's Avatar
Send a message via AIM to GurgenPB Send a message via MSN to GurgenPB Send a message via Skype™ to GurgenPB
Arrow Wideband AFR Shootout
Hey Guys
This confirms pretty much everythign i have been saying about the Innovate! Motorsporsts wideband o2 sensor products.
Here is a shootout that was done by Ford Muscle magazine (unbiased).
http://www.fordmuscle.com/archives/2...tout/index.php
Here is a quick snippet:
P.S. For all those that were defending Zeitronix a while back, here is a quote from the article:
"The Zeitronix exhibited accuracy of +/- .54 AFR, and gradual lean drift under some conditions. The included logging software was relatively difficult and lacked features. "
... not to mention PLX (+/- 1.00 AFR)
__________________
- Gurgen
2003 G35 Sedan 6MT powered by MoTeC M800
Power Enterprise® TT @10-16 psi, Custom 5" deep FMIC, GTM®-built Engine (Arias®/Pauter®/GTM® Cams/12mm ARP®), PE® 550cc@4.5bar (683cc) inj, Motordyne® Iso Thermal MREV2/0.5" spacer, APS® 3.5" pipes, Custom TD 3" Exhaust, ATS® Triple-Disk, Tein® Flex
GurgenPB is offline   Reply With Quote
Old 06-27-2007, 04:38 PM   #2
THE TECH
My Garage
THE TECH's Avatar
Send a message via AIM to THE TECH
Hmm...for how much of a PITA it is to install and use the Innovate, I'll stick with my FAST.
__________________
03 Z SOLD, 04 Z NOW
THE TECH is offline   Reply With Quote
Old 06-27-2007, 04:42 PM   #3
failsafe306
My Garage
failsafe306's Avatar
Send a message via AIM to failsafe306
I thought the PLX would be far better than that, +/- 1.0 is pretty nasty
I'll stick with my AEM though. Although the latency is almost 1/2 a sec
failsafe306 is offline   Reply With Quote
Old 06-27-2007, 04:49 PM   #4
paranormal
BigThingsPoppin
My Garage
paranormal's Avatar
i still to this day.. 2 years now have not had my Innovate working.. hopefully gtm can get it working soon. the aem serial gauge is going in too so ill have that reading also
__________________
WSOP or bust!
paranormal is offline   Reply With Quote
Old 06-27-2007, 04:49 PM   #5
gNaRKiLL
My Garage
gNaRKiLL's Avatar
I dont see how the afr's could differ that much. I mean all your really paying for is an a/d convertor, with a built in calibration curve for the specific type of sensor that it requires. The only thing I could think is that some of these companies use lower bit a/d convertors than others which would cause the accuracy to drop significantly. Interesting find though but I really dont see how they could differ that much unless they are doing what I stated above.
Innovate does have some really nice software though and they make it really easy to hook right up to your computer.
gNaRKiLL is offline   Reply With Quote
Old 06-27-2007, 04:51 PM   #6
stormcrow
I Did Twins
My Garage
stormcrow's Avatar
Send a message via AIM to stormcrow
i'm still partial to NTK based sensors (for longevity and accuracy) over the bosche based systems... but, the innovate is what i have for the moment... i wonder how long it will last (the sensor) on C18... only time will tell...
stormcrow is online now   Reply With Quote
Old 06-27-2007, 05:23 PM   #7
booger
My Garage
booger's Avatar
I'll atest to the Zeitronix being off . My shop had a brand new Inovate W/B on his dyno . We both logged runs . My Z was off by at least .50 of a point most of the time...mine on the lean side.
__________________
a man wrapped up in himself makes a small bundle
booger is offline   Reply With Quote
Old 06-27-2007, 05:34 PM   #8
GurgenPB
UltimateSleeper
My Garage
GurgenPB's Avatar
We are talkign about objective data here... how can one assert that one unit performes in a certain way vs another unit going by 'feel' is beyond me.
The accuracy has nothing to do with the A/D converter actually, it's how the pump current is applied and regulated (from what i understand) is what makes one controller better than the other. A/D has to do with the accuracy of retaining and transmitting the values to the display device.
as far as the ease of installation is concerned... think about this for a second...the innovate is harder to install given the multitude of grounds that you have to connect, namely the separate heater and system ground. This is a high precision device and in order for it to be high precision this is absolutely required...think of the OEM WB sensors, they all have descrete grounds going to the ecu (with the built-in controller), this is wha it takes to be accurate. I'd rather spend 30 extra minutes to actually read the instructions and wire two extra wires and be able to COUNT on my sensor than save the 30 minutes and be off by up to a full point.
__________________
- Gurgen
Old 06-27-2007, 05:41 PM   #9
QuadCam
My Garage
QuadCam's Avatar
anyone ever compare the Innovate to the TXS Tuner Wideband?
__________________
2005 G35 Twin Turbo Sedan
QuadCam is offline   Reply With Quote
Old 06-27-2007, 05:42 PM   #10
IIQuickSilverII
-Overlord-
My Garage
IIQuickSilverII's Avatar
Send a message via AIM to IIQuickSilverII Send a message via MSN to IIQuickSilverII
yeah thats BS..i got the plx r-300(i guess not the m300) and i read 0.10-0.25 in accuracy with what the real A:F was on the dyno
__________________
my Z33 build by intensepower.com
IIQuickSilverII is online now   Reply With Quote
Old 06-27-2007, 05:52 PM   #11
GurgenPB
UltimateSleeper
My Garage
GurgenPB's Avatar
A/Fs on the dyno are NOTORIOUOSLY wrong. IMHO you can't trust them period.
__________________
- Gurgen
Old 06-27-2007, 05:54 PM   #12
THE TECH
My Garage
THE TECH's Avatar
Quote:
Also since most dyno places use the tailpipe sensor, readings will be different than those further upstream in the exhaust system.
__________________
03 Z SOLD, 04 Z NOW
Old 06-27-2007, 06:52 PM   #13
IIQuickSilverII
-Overlord-
My Garage
ill check with my data long on the utec.. i am pretty sure its accurate though cause i test it in a couple of places
__________________
Old 06-27-2007, 07:07 PM   #14
GurgenPB
UltimateSleeper
My Garage
GurgenPB's Avatar
Quote:
Absolutely, that too!
__________________
- Gurgen
Old 06-27-2007, 07:29 PM   #15
IIQuickSilverII
-Overlord-
My Garage
ill try to post the info with pics later...bt i am at 0.09-0.21 with he utec datalog
i think maybe its the m-300 unit and not the r-300 unit the one that sucks with the plx thing
__________________
Old 06-28-2007, 02:16 AM   #16
KPierson
KP Technologies
My Garage
KPierson's Avatar
Send a message via AIM to KPierson
From what I have read, it has more to do with the heater circuit. The heater must maintain a constant temperature for accuracy. If the temp varies at all, the measurements will be off. So, I'm guessing it would come down to who has the best tuned PID heater loop.
__________________
Kevin Pierson - Built APS TT 2004 DG 6MT G35 Coupe
***Take control of YOUR car!***
KPierson is offline   Reply With Quote
Old 06-28-2007, 02:39 AM   #17
tyrone coupe
My Garage
tyrone coupe's Avatar
The 0.5 difference is quite possible on Zeitronix based on the data I have logged and the info given to me when my car was tuned.
Tuner said 11.9 mid tappering to 11.4 on Top.
I seem to be logging 12.5 tappering of to around 12-11.9 on the Zeitronix.
I am boosting 8 psi which is spot on to what the car was tuned.
I have however found that the ease of use is extremely user friendly especially setting the warning parameters etc.
tyrone coupe is offline   Reply With Quote
Old 06-28-2007, 03:58 AM   #18
Alberto
Cranky FI Owner
My Garage
Alberto's Avatar
Send a message via AIM to Alberto
Innovate is easy to install and set-up I didnt have issues with mine and I hate any kind of electrical/wiring. I guess spending another 20 minutes on an install isnt worth accurate A/F's
Alberto is online now   Reply With Quote
Old 06-28-2007, 04:03 AM   #19
Audible Mayhem
My Garage
Audible Mayhem's Avatar
Send a message via AIM to Audible Mayhem Send a message via MSN to Audible Mayhem
the innovate and the tuner wb from turboxs are very very similar, thats pretty much the combo i use to tune twin turbo cars and cars with dual exhausts....
i cant believe aem came in second, i truely hate that wideband cause it jumps around sooo much, i think maybe its just the delay when it displays and it is catching up....
Audible Mayhem is offline   Reply With Quote
Old 06-28-2007, 06:28 AM   #20
THE TECH
My Garage
THE TECH's Avatar
Quote:
It's possible that Innovate has changed what you have to do to install their units in recent years since the last time I installed one.
__________________
03 Z SOLD, 04 Z NOW
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
