ATI Procharger SC pulley for 20psi+
Old 08-24-2007, 01:46 PM
Jay'Z
Jay'Z's Avatar
Exclamation ATI Procharger SC pulley for 20psi+
Anyone know how I could get a pulley for over 20psi.. I called procharger and they said they only make up to 11psi=weaksauces.........
Hoping prob some FI Vendors will chime in.. or anyone with SC pulley knowledge........ I know my teeth count is .. like 40/22 I cant get a good read on it right now..
If I could get like 42/18 that would be sick.. or maybe even 44/16
Old 08-24-2007, 01:58 PM
klimaxx805
klimaxx805's Avatar
Try these guys http://www.aspracing.com/frame.htm
--Frank
Old 08-24-2007, 02:06 PM
Jay'Z
Jay'Z's Avatar
--Frank
Thanks Frank! So far it looks as they have nothing for the C-2.. I may have to call tomorrow..
Old 08-24-2007, 02:36 PM
booger
booger's Avatar
jon
Ive never got a good look at a ATI blower kit . Does it have a serp pulley coming off the crank pulley . That turns your longer cog belt ????
Old 08-24-2007, 02:44 PM
Jay'Z
Jay'Z's Avatar
Originally Posted by booger
jon
Hold up.. Ill post pics.......
Old 08-24-2007, 02:47 PM
Jay'Z
Jay'Z's Avatar
Its the two cogs on the end of the belt.. The lower one by the radiator.. and the upper one by the radiator cap.. Those control boost..
Old 08-24-2007, 02:53 PM
booger
booger's Avatar
So it has a cog pulley bolted to the crank ? Or a serp pulley and belt that turns the two cog belts I see in the pics
Old 08-24-2007, 02:56 PM
Jay'Z
Jay'Z's Avatar
serp....... lemme post pics of bumper off...... http://www.exoticperformanceplus.com....html?item=394 scroll down..
Old 08-24-2007, 03:10 PM
booger
booger's Avatar
OK...none of them showed me what I was asking .
You have two cog [toothed ] belts . The longer one turns the jackshaft [ front bumper side of bracket ] which turns the blower belt [rear bumper side of the bracket ] . What I was trying to find out is . WHat is coming off the crank pulley to turn your first cog belt I see in the pics ? Is it the serp belt that turns the AC pump and power steering pump ????
Old 08-24-2007, 03:14 PM
Jay'Z
Jay'Z's Avatar
Yes.. Ill go take pics of the actual shizza now.. BRB
Old 08-24-2007, 03:17 PM
sentry65
the burninator
sentry65's Avatar
oh man, is that tiny little mini AC belt really responsible for turning the entire cog pulley system on the ATI kit?
Old 08-24-2007, 03:28 PM
Jay'Z
Jay'Z's Avatar
Here are the pics..
Old 08-24-2007, 03:36 PM
sentry65
the burninator
sentry65's Avatar
oh, so it uses a longer main belt to turn a pulley that is connected to the cog
Old 08-24-2007, 03:38 PM
Jay'Z
Jay'Z's Avatar
Foshizzle.......
Old 08-24-2007, 03:45 PM
booger
booger's Avatar
It looks to be the Power steering pump pulley belt ...If Im looking at it right . Either way it does have a shorter serp pulley belt and that is why the ATI is able to build a few more psi than the vortech . I think Trefling was able to get his to 15psi before the belt slipped . M ight want to PM him and ask about what pulley's hew used .
Old 08-24-2007, 03:48 PM
Jay'Z
Jay'Z's Avatar
I got the same pulleys he used.. I want more power, over..
I already have the 14-16psi pulley.. I want a 20 psi pulley or more.. So i can hit high boost earlier in the rpms.. And smoke shiiiiiiiiiiiiiiiiiiiet.. BTW well see how she does with the new belts on tuesday.. Maybe it was all the belt alignment that made me lose so much hp... I should have waaaaaaaaaay more than 420whp/377tq
Old 08-24-2007, 03:59 PM
booger
booger's Avatar
Good luck Tuesday !!!!
Old 08-24-2007, 04:12 PM
jumpin800agl
8 to 11
jumpin800agl's Avatar
[QUOTE=jonb7007]I got the same pulleys he used.. I want more power, over..
I already have the 14-16psi pulley.. I want a 20 psi pulley or more.. So i can hit high boost earlier in the rpms.. And smoke shiiiiiiiiiiiiiiiiiiiet.. BTW well see how she does with the new belts on tuesday.. Maybe it was all the belt alignment that made me lose so much hp... I should have waaaaaaaaaay more than 420whp/377tq[/QUOTE
You smoke shieeet? Dang I figure you just smoked Privates. God luck with the new belts.
Jay'Z
Jay'Z's Avatar
Thanks, I think it was the belts/alignment though.. If you look at eltness Sig he made 430whp at 11psi..
Old 08-24-2007, 05:46 PM
Jay'Z
Jay'Z's Avatar
LMFAO!!!!!! u stupid man..
Fixxxercask
11-09-2015 11:10 AM
NissanZcrazy
09-23-2015 07:59 AM
EnjukuRacing
09-11-2015 08:34 AM
Quick Reply: ATI Procharger SC pulley for 20psi+
