Octane Booster Review
on
Sorry if this is a REPOST.
Interesting review of different Octane Booster (Including Toluene).
http://www.sportscarforums.com/f13/t...oice-3257.html
It's Typed Version of the Article:
Octane boosters are popular in the performance scene because they often regain power last through detonation. Sold for around $25 in a handy bottle, they’re a convenient fuel additive and horsepower helper. But with so much brands on the market, you may be fooled into thinking they’re all as effective as each other. Which they’re not! Differing chemical compounds, additives and even volumes, mixed in with a good percentage of advertising, ‘independent" testing and testimonials all conspire to confuse the consumer away from the single most important paint: does it improve the octane rating?
Let’s see what’s worth it in octane boosters.
DO I NEED AN OCTANE BOOSTER?
The boys at "The Macquarie Library" describe detonation as: "Excessively rapid burning of the fuel mixture, often caused by auto-ignition due to excessive temperatures in the combustion chamber, incorrect ignition timing, lean mixtures, too high a compression ratio or unsuitable fuel," – as in too-low an octane rating.
Heard as a faint, metallic rattle, detonation is accompanied by a loss of power and can cause serious damage to piston crowns.
The significance of detonation is such that many companies produce fuel additives designed to increase the inherent octane rating of a given fuel. The proliferation of octane boosters has in part come about in recent times thanks to low quality Australian fuels. White or "Super" leaded fuel has been reduced from 98 to 95-96 octane, Premium Unleaded has also dropped to a minimum of 95 octane. And this presents a problem for high-performance cars designed to run on higher octane European or 100 octane Japanese fuel. Japanese import performance cars, Subaru’s STI WRX for example, runs an ECU program for 100 octane, but sometimes detonates on our Australian PULP.
All engines are different though and with Honda’s S2000 2.0-litre engine running a high 11.0:1 compression ratio, it relies on advanced engine management as much as quality fuel. But it can sustain its power on PULP. And of course any turbo owner who has experimented with boost will know if you run too much, it will detonate, so improving the octane is vital for maximum performance.
We must state that unless an engine is detonation through low RON fuel, octane boosters have little use. However, in a turbo or high compression application, the inclusion of a better grade of fuel allows the engine management system to optimize ignition timing and fueling.
THE CONTESTANTS
For this test we tracked down nine different makes and models of octane boosters, two fuel "additive," a straight race fuel and a drum of Toluene. Where there were several different "levels" of octane boosters in the one brand, we chose the strongest version.
The biggest claims the bottles have is the amount of "points" they claim to increase. This is ambiguous as a "point" can relate to either 1.0 RON (Research Octane Number) octane points, or 0.1RON octane points.
The list of entrants in our octane Olympics included:
STP Octane Booster
Wynns Octane 10+ Power Booster,
Amsoil Series 2000 Octane Boost,
Super 104+ Octane Booster,
VP C5 Fuel Additive,
ELF HTX 330 Racing Fuel Stabilizer,
Nulon Pro Strength Octane Booster,
PowerFuel Super Street Nitro Based,
PowerFuel Max Race Nitro Based,
NF Octane Booster Racing Formula,
NOS Octane Booster Racing Formula,
Toluene,
VP Motorsport 103 Unleaded Racing Fuel
THE TEST
To conduct these tests we contracted independent laboratory Intertek Testing Services, who would test our products on a knock engine.
We had to also find a base fuel to add our boosters to so we went to the closest public petrol station, a Shell on the outward-bound side of the Westgate Bridge in Melbourne.
Being a performance-based test, we chose premium unleaded fuel as this represents the most common high performance fuel (ie: if you start with regular unleaded, you’re wasting money!). We should add that "some" boosters would have improved the octane rating of regular unleaded proportionately more than our tests with PULP.
With a RON rating at a minimum of 95, we first established the exact octane of the PULP. The biggest surprise was our randomly select Shell resulted in a quite high 96-8 RON.
We precisely measured and mixed each additive to the PULP, according to each manufacturer’s recommendations and specs and poured each into the knock engine’s tank. The compression ratio was then slowly increased until it started to knock, gaining a threshold of detonation and subsequently a maximum RON rating.
Of less importance but still worth mentioning is the design of the bottles: since most people will be pouring it straight into a tank, the design of a bottle is important to prevent any spillage on paintwork causing damage.
So let’s look at the results!
THE RESULTS
BASELINE OCTANE 96.8
Octane points
It’s very easy to confuse octane ratings as there are a number of separate international standards. MON (Motor Octane Number) is the number derived from a fuel when it’s applied to a test engine run at 3000rpm rather than 600rpm and higher inlet temps and ignition advance. The Australian importer of 104+, Andrew Holdsworth, suggested MON is seen as a more real-world test.
Though none of the fuel companies promote the MON figure which is normally between 7 and 10 numbers less than RON (Research Octane Number).
Intertek’s Graeme Marks believes RON provides the general public with an idea of which additive works more effectively. And being the most commonly-used reference, we’ve used RON for all our tests.
11th
946ml treats 35 litres RRP: $35
Right from the start, we were told PowerFuel’s additives weren’t necessarily octane boosters, but horsepower helpers. We kept this in mind when testing both the products, but of the two only the Super Street claimed it was specifically designed to increase the octane rating of PULP. With a 20-percent nitro mix, Super Street Nitro-Based still improved octane ever so slightly (0.2RON) but the real test for these two would come on the dyno runs.
OCTANE IMPROVEMENT: 97.0 (+0.2 RON)
10th
PowerFuel MaxRace Nitro Based
946ml treats 35 litres RRP: $45
Containing another 15 percent more nitromethane than the SuperStreet formula, MaxRace doesn’t claim to increase octane, but the verbal recommendation was the same, ie: its main characteristic is to boost horsepower, not octane. For a fair comparison of these two additives, you need to look at the power they produce. As for octane, it proved very similar toe the SuperStreet formula bumping up octane ever so slightly.
9th
STP Octane Booster
350ml treats 57 litres RRP: $10.95
One of the cheapest of the group, the STP was also one of the hardest to find. Auto stores either didn’t stock it, or had simply run out! Claiming to increase the octane 2-5 points, in a well-designed-for-pouring bottle, the STP – used in the ratio determined by the label - improved the octane marginally by just over half a point. A little disappointing unless you interpret STP’s claim actually meant 0.2-0.5 points. Then it’s a good result!
OCTANE IMPROVEMENT: 97.4 (+0.6 RON)
8th
325ml treats 60 litres RRP: $10
The Wynns was the cheapest of the lot and claimed an increase between two and five points, again not actually listing what a "point" related to. Strangely though the 10+ could indicate 1RON and if this is the case going by our tests it almost lived up to its name. It didn’t quite live up to its claims however, increasing the octane rating by 0.8RON.
OCTANE IMPROVEMENT: 97.6 (+0.8 RON)
7th
473ml treats 83 litres RRP: $25.95
The acknowledged winner of all previous testing in this country, Super 104+’s bottle stated we should expect an increase between four and seven point. With a new formula introduced about 12 months ago, identified by an "Eagle" logo on the back of the bottle, the Super 104+ seems to have lost its edge with a marginal gain of just less than 1.0RON.
OCTANE IMPROVEMENT: 97.5 (+0.9 RON)
6th
VP Racing C5
355ml treats 75 litres RRP: $19.95
VP has a strong reputation with fuels and its high octane formulas are very popular (VP?) with drag racers. VP Racing’s C5 Fuel Additive lacked any indication of contents nor claims, but the C5 additive still provided a reasonable increase of 1.3RON.
OCTANE IMPROVEMENT: 98.1 (+1.3 RON)
5th
355ml treats 60 litres RRP: $28
NOS, a relatively new octane booster, comes in "1/10th" scale bottles designed to emulate the actual nitrous bottles of its successful NOS systems. The Racing Formula is the strongest of three concentrates and containing Hydrotreated Aliphatics and Methylcyclopentadienyl Manganese Tricarbonyl (try saying that 10 times in a row), it contains a lead replacement which NOS claims increases the octane rating by as much as seven points. Obviously not recommended for street use, it also included with a handy pouring spout. In testing, it proved a good result improving the octane rating by almost 2RON.
OCTANE IMPROVEMENT: 98.6 (+1.8 RON) as much as 7 points
THE CONTESTANTS
STP Octane Booster
Toluene,
THE TEST
THE RESULTS
Octane points
11th
10th
9th
STP Octane Booster
8th
7th
6th
VP Racing C5
5th
on
CONT...
4th
ELF 330 Fuel Stabilizer
1000ml treats 50 litres RRP: $45
"If you spill it on your paintwork, don’t rub it off – rinse it with water" were our works of warning. We were also told to "pre-mix" the ELF before adding it in a fuel tank (which with this test we were doing anyway) as the ELF has a tendency to settle to the bottom of fuel if it’s either not mixed properly or left to sit. This was made somewhat more difficult by the design of the bottle, which tends to drip when pouring. With some nasty stuff known as Aniline, the ELF doesn’t claim any numbers, and provided a decent 1.8 RON point improvement.
3rd
354ml treats 57 litres RRP: $23
Recommended for off-road and racing use, the Amsoil Series 2000 claimed to increase the octane rating by up to seven points. It came up a little short, but still proved surprisingly good with a full 2.0RON improvement. And good enough for the bronze medal in our Octane Booster Olympics.
OCTANE IMPROVEMENT: 98.8 (+2.0 RON)
2nd
Toluene (Toluol)
20 litres treats 100 litres RRP: $48
Since toluene (pronounced toll-you-een – also known as methyl benzine) isn’t a commercially advertised octane booster. We were unsure of exactly what ratio to mix the clear Toluene to the fuel, with recommendations between 10 and 30 percent. From personal experience, we have seen high percentages increase octane even further, though 30 percent is considered the maximum. Available only from various fuel distributors (it is a special order through services stations), under advice we ran a 20 percent mix (quite a lot more than the others) and saw an impressive improvement of 2.5 RON, for the silver medal.
OCTANE IMPROVEMENT: 99.3 (+2.5 RON)
1st
250 ml treats 80 litres RRP: $29.95
Time for an Aussie-made product. From Perth, the NF Octane Booster Racing Formula was the smallest bottle in the field, but looking at the mixing ratio, also the strongest NF relies on an incredibly small dose – a mere 3 percent! Claiming to increase octane as much as 6.0 RON, NF took the gold medal in a surprising tie. If it were a split decision based on concentration though, it would be the clear winner.
OCTANE IMPROVEMENT: 99.6 (+2.8 RON)
1st
500 ml treats 60 litres RRP: $20.95
Note: Also available in four-litre container for $110
The Australian-made Nulon Pro Strength Octane Booster is the top of the range Nulon fuel product, claiming to boost octane "up to seven number". The Pro Strength gained a test-winning, gold-medal-gaining and Nf-equalling 2.8RON increase. And at $21, it’s good value too!
VP Motorsport 103 fuel
Used straight fuel (20-litre minimum) RRP: $70
Purely for interest, we decided to also test a straight racing fuel. While there are a number available (such as ELF) for no particular reason we chose VP. The highest octane VP fuel which was still totally street-legal was the Motorsport 103. Working out at $3.50 per litre and "designed for maximum power and throttle response", the VP was very impressive with an octane rating of 107RON – more than 10RON points more than PULP. Obviously more expensive than the boosters, if octane is problem, racing fuel like VP may be the answer.
OCTANE IMPROVEMENT: 107 (+10.2RON)
As the name suggests, a knock engine is designed to test the detonation or anti-knock rating of fuels and fuel additives. It’s a slow revving engine capable of running most fossil fuels through an adjustable compression ratio. As the comp ratio increases, it accurately measures the intensity of the knock and determines the fuel’s octane rating.
The world standard is a one-cylinder two-valve four-stroke engine with exposed valve gear. Archaic in appearance, a carby is fed from any one of three fuel bowls to allow three different fuels to be run back to back. The mixture is actually controlled via gravity feed and by raising or lowering the float level of each bowl!
Run under load via a belt-drive linking the flywheel and load system, it ensures a real world situation and ensuring minimal variation between tests, oil temperature, intake air density and air temperature are all monitored and controlled.
The engine is somewhat agricultural, however its unique ability to vary the compression ratio while running between 5.0:1 and 15.0:1 is quite amazing. The operator simply winds a handle and the entire head and cylinder assembly moves up and down relative to the crankshaft.
A knock sensor measures both the frequency and intensity of the ping (as displayed on a knock metre). Figures are then cross-referenced on a chart using the information provided by the knock meter, plus the height of the head and barrel.
Finally, knock intensity is figured in and the fuel’s octane rating determined.
Taking two hours to warm, this $200,000 engine is super robust and rarely needs rebuilding. Individual tests can then proceed at approximately $120 per test sample.
Being subjected to so much detonation, you can only imagine how much maintenance an engine of this nature must need. Interestingly, this isn’t the case as the piston and rod assembly are rejects from a monstrous ship engine (just kidding)! They’re frigging huge with the incredibly thick piston crown contributing to a combined gudgeon pin and piston weight of 1794 grams! Likewise, the rod weighs an astonishing 1929 grams. The bottom line is these engines which have replacement value of over $200,000 and almost never require rebuilding.
DYNO BOOSTERS
Ultimately, the role of an octane booster, is to regain horsepower lost through detonation or retarded ignition timing due to detonation. But two of our products, the nitro additives, weren’t specifically designed to increase octane. Instead, they contain a mix of nitromethane (the petrol Top Fuellers run) in a "percentage" concentrate. Power Fuel’s Super Street and Max Race additives has 20-percent and 35-percent nitro respectively, and the Australian importer specifically claimed they would increase power, not necessarily octane.
So, we took those two products, and the two best-performing octane boosters to MRT Performance for some Dyno Dynamics dyno testing. Interestingly, we were going to use MRT’s rally Civic, which normally runs on avgas. On PULP – even with the booster – it was pinging too much, so a Jap-spec EF Honda Civic was used with a 1.6-litre VTEC and about 10.0:1 comp ratio.
The graphs tell the story though, and to be fair to the products, with variables such as heat soak, the results weren’t as conclusive as could be gained from an engine dyno. But that is not to say the products don’t work. As our test prove, they do, but it’s not as easily measured on a chassis dyno. Plus the Civic had no detonation problems on PULP, further hampering the "apparent" effectiveness of the boosters.
With changes too small to accurately measure, we would suggest if your engine is sensitive to octane, a booster is for you. If not, try the nitro or racing fuels.
CONCLUSION
Both the Nulon Pro Strength and the NF Racing Formula rated the best octane boosters in our test. And considering that less NF was needed than Nulon, it evens out a little with a slightly higher cost. Still, both proved extremely effective at increasing octane, even outranking Toluene, which needs much higher levels of concentration. The VP Motorsport 103 fuel was an interesting exercise, and if a little more effort (ie: buying it from the selected outlets) is worth the octane, it’s a good representative of what to expect from straight racing fuel. As for the nitro additives, if you’re not experiencing any type of detonation, they’re definitely worth a try. So whether you detonate or not, we’ve found a fuel additive for you!
4th
3rd
2nd
Toluene (Toluol)
1st
1st
DYNO BOOSTERS
CONCLUSION
the burninator
further proof that octane boosters suck and that you should just get racing fuel for 4-10x the effectiveness and about the same price as an octane booster...not to mention it'll probably be more evenly mixed than a can of octane boost will mix with your gas tank
on another note, damn I wish we got 96.8 octane here as regular premium like in australia
I'd bet the octane boosters would be more effective if used with 91 octane gas...
on
but for some Race Gas is hard to get or at least a few hrs drive. Even the best octane booster out there won't get you 3+ point like a Race Gas can but 2.0 point is not bad.
on
The top 2 Octane Booster are hard to find coz they are imported. Toluene is cheaper but you need a bigger storage for them. Now the third best is Amsoil Series 2000 Octane Boost and they are about $9 and good for 15 gallons. Water/Meth is great and cheap but you only spray on mid-high boost. If you set your water/met to spray all the time then that add up to a good $$$ and if the kit fail then you risk yourself of leaning out to much (most of my friend never had their kit failed though)
the burninator
yeah but why would the water/meth need to actually spray all the time? You're either getting on the throttle or you're going easy on the throttle. On most cars detonation usually only happens when you're giving it some amount of throttle
It's not like most cars have a 15:1 compression ratio or something where they could possibly detonate/preignite just from the engine starting
on
Check this TORCO Unleaded Concentrate 104 Octane
http://www.jbsblownc5.net/html/torco.html
"Get TORCO for $85.00 a case of 6 cans. The unleaded concentrate when mixed with 91-93 octane super unleaded gas makes up to 104 octane race fuel.
Take a case with you and never worry again about not having high octane racing fuel on hand"
Independent test showed going from 91.8 to 96.5 with Torco.
Here's one thread
http://forums.corvetteforum.com/showthread.php?t=776542
Here's one thread
on
Do your own Mix
Found this if you want to do your own mix.
Editor's note: I would NOT suggest that a person use the following fuel mixtures without considering the detrimental effects on your engine, vital engine components (O2 sensor, etc), and other potential damage. That said, the information is interesting.
Original published in:
GS-Xtra
1213 Gornto Road
Valdosta, GA 31602
(912) 244-0577
Editor: Richard Lasetter, president Gran Sport Club of America (GSCA)
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
Sample Mixture
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses.
Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
GS-Xtra
1213 Gornto Road
Valdosta, GA 31602
(912) 244-0577
R+M/2.........114
Formula #2 - Xylene
R+M/2.........117
R+M/2.........118
R+M/2.........101
R+M/2.........101
Sample Mixture
on
Don't confuse RON and MON test and numbers MON is much more applicable to a modern penta roof 4 valve engine.
Chemistry of Octane numbers:
http://acta.chem-soc.si/53/53-3-306.pdf
on
Yes, USA use MON so the value should be lower compared to RON. The review is just a guide which one is the best but it may not be satisfactory for most people. Conclusion is just mix 20%-40% of Toluene or Xylene will yield better result than most of the octane boost in the market. Torco Octane booster have so many followers in the Domestic Cars and swear about them.
MOTORDYNE-MY350Z SPONSOR
There are a few details about the aeromatic rings (benzene, toluene, xylene) that should be known.
They all increase the octane value similarly but their burn rate differs quite a bit.
Xylene will increase octane but that stuff burns very, very slow. So slow its often incomplete and is expelled as soot.
Toluene also burns slow but its a lot better than xylene.
Benzene on the other hand boosts octane and burns a lot faster.
Faster burn = more HP/TQ/efficency
Benzene>Toluene>Xylene
on
Yes they do burn slow because of the weight difference and that is why you don't want to run more than 40% mix. Also, be careful buying hundreds of gallon of Toluene coz that is being monitored by the DEA. Xylene is not much of a problem coz it is not being monitored, so pick your poison.
on
What amazes me is that they list Analine as an ingredient of one of the additives listed in the comparison.
Analine is a lot more trecherous than benzene when it comes to toxic substances.
Analine soaks into the skin on contact, invades the blood stream, permeates cells, attaches to DNA, cyanosis, vomiting, hallucinations, coma and so on.
Its the amino group that makes it so bad.
Nasty. It shouldn't be sold to the general public.
