CJM Twin pump Install pix!!!
on
Sorry no pix at this point but, the 2nd pump is controlled through 30amp relay with an independent ground. Charles supplied all the needed spade connectors to connect into moldex connectors. Very simple!
Kevin
Kevin
on
Your car has gotten just crazy perfect. I will be @ the dyno one way or another. As always, just beautiful top notch attention to detail. You seriously consider a change in profession bro!
S
S
Originally Posted by kevinapex
Black and blue soldered to sending unit connections (center cone is the return defuser)
Thank you for the pics. You definitely answered a lot of questions. Great job. Another DIY'er. A man after my own heart. Nice!
CJ Motorsports
Originally Posted by rrmedicx
When you say center cone are you referring to that cork looking thing? That is a diffuser? or does it cover the diffuser? Does it attach to anything?
#39
on
Great work guys. Nice to see and worth the wait. It's a very interesting design to say the least. I'm curious as to how the siphon works if the return terminates w/ a diffuser at the top of the unit. I see the holes at the bottom of the unit also...do these have something to do with the siphon? I also notice you're not using Walbro GSS342's or 341's...it's that funny one with the snap on sock filter. I hope I'm not prying into propriatary information. I just want to know how you addressed the saddle tank siphon issue.
Thanks. Great work again guys!
