Forced Induction for Noobs....
#181
on
Slidefox.. A few more - Sorry for all the questions but I dont want to get flamed for starting a post that I should have searched about even though I could not find it.
1. Are all Turbo Timers created equal? Or is there one I should go with? I almost feel like I could get an eBay crap one and it wouldnt matter but I could be completely wrong.
2. Should I heat wrap or ceramic coat my turbo piping? If "yes" which pipes and how should I coat or heat wrap them ?
3. What is a good exhaust to go with that sounds and looks stock to go with my single turbo Z?
#182
2. Heat wrap definitely doesn't hurt. I would wrap your down-pipe and up-pipe. This might be beneficial since you are running a Turbonetics Kit which is notorious for high AIT's; due to the design of the kit.
3. My personal favorite.... JIC Spartan DE Type 1. The Full Ti sounds incredible, but costs a grip. I would spring for the ST or the SUS.
http://www.intensepower.com/exhaustheaders.html
#184
Firewall is usually a common place.... I've seen some people mount there boost solenoid on the strut tower wall on the passenger side of the engine bay as well.
#188
on
Slidefox...i have a question for you, this post has helped me alot but since im a noob(ill admit it) i have a 2006 350Z and i have found the kit listed below, my question would this work on my 06 ive done some looking but have not found a def. answer and he is askind 4800 for it all is this a good price?
thanks for your time
TDO5H-18G cast manif., ext. w/gs, w/ e-manage, & 440cc inj.
TurboCharger TD05-18G 8CM^2
Wastegate (GReddy /Tial) .45 Bar
Manifold Right left
Downpipe Adapter Right right
Compression Pipe C-1 ~ C-5 RRRL
AirFlow Meter Adapter & Suction pipe RR LL
Airinx AY-SB (Blue) & Airinx hose adapter S70
Oil Pressure Hose USS & UNION FITTING & BANJO FITTING
Copper Washer
Oil return pipe right left & Oil Pan with welded Oil Return Pipe
Vacuum Hose
Radiator Reserve & Rubber & Silicone Hose
Hose Band
Power Steering Pump Fitting & Check Valve
Radiator reserve trank / cap
Hose Fitting & Radiator Reserve Tank Bracket
Aluminum Spacer & Airinx Bracket
Exhaust manifold gasket & Turbo gasket & Catalytic converter & Oil Return
Thermo Cloth & Three way fitting & Zip Ties
E-manage US-Z33 & Injectors 440cc
Manifold Right left
Copper Washer
Vacuum Hose
Hose Band
#189
Manifold Right left
Copper Washer
Vacuum Hose
Hose Band
Manifold Right left
Copper Washer
Vacuum Hose
Hose Band
Just make sure it has everything that came with the kit originally, and if there is anything missing, to make sure you are aware of it.
Also, make sure it is for a Z and not a G...
#191
on
WOULD IT BE POSSIBLE TO GET A BREAKDOWN OF THE NEW EMS OUT THERE, HALTEC, PRO EFI, FCON. FEATURES, CAPABILITIES, PROS CONS. I KNOW WHEN HALTEC AND PROEFI FIRST CAME OUT THEY SAID THEY WERE HAVING UPDATES ON THE FEATURES. WHAT ARE ALL THE CAPABILITIES NOW?
#192
I will admit, I know just about all of the EMS's that are available, but as far as EVERY feature for EVERY EMS. That would require some research.
I'm sure if you search the "Tuning" section or the "Product Announcment" section in Forced Induction, there should be threads about the Haltech and the ProEFI. As far as the HKS F-Con goes, there is plenty of information out there.
I can put something together, but I wouldn't expect it anytime soon. Sorry.
#194
I would go ProEFI, because the owner/Head Engineer for ProeFI is local to me, and I know him.
Second choice would be Haltech. Only for the reason that the HKS F-Con V-Pro can only be tuned and installed by an HKS Pro Dealer, and a dealer might not be local to you.
#195
on
bro i enjoyed reading this seriously my z i stock but what kit would you recommend im trying to drag dift and i want that power so when an evo rolls up on me i want to easily kill him freeway or off the dig thanks alot bro
#196
Judging by your username, I am going to assume you have an HR and not a DE??
#199
on
Okay I am as nooby as they come to f/i. I want power but nothing crazy. Maybe at most 450whp. Now after reading this I could achieve close to that with aps single turbo kit. My question is though for doing a mild build would it suffice to just build the bottom end? New rods, pistons,and sleeve it? or would I need to do more?
#200
If your set on APS, and a mild build.... Do Pistons, Rods, Standalone EMS, Return Fuel System w/ at least 600cc Inj., and a clutch and flywheel to hold it all. Cams will help you in the top end if you can budget it, but the stock heads are A OK.
