Brake Boosting FTW!!11
Old 12-04-2008, 01:56 PM
  #41
Blackbird CPV35
Blackbird CPV35's Avatar
Originally Posted by KPierson
It will throw a code after X amount of miles and will cause the cruise control system to not work.
fyi my Cruise Control stopped working even with the switch, it just blinks rapidly and reconnecting the wire didnt fix it
Old 12-04-2008, 02:02 PM
  #42
KPierson
KPierson's Avatar
You must have kept the switch open too long. Once it throws a code you have to clear the code before the CC will start working again.
When I was messing around with this I noticed that sometimes I could drive hours and not throw a code but somtimes it won't take much at all.
Old 12-04-2008, 05:56 PM
  #43
Blackbird CPV35
did u clear the code by using the standard gas pedal reset?
Old 12-04-2008, 06:12 PM
  #44
KPierson
KPierson's Avatar
No, I reset it through Cypher or my OBDII reader. I never tried the gas pedal method as I always have Cypher or my OBDII reader with me.
Old 12-04-2008, 07:03 PM
  #45
Blackbird CPV35
damnit, the gas pedal reset didnt work for me. i hate not having CC
Old 12-04-2008, 07:11 PM
  #46
str8dum1
str8dum1's Avatar
how about a battery disconnect.
I guess the moral is, dont leave the switch open for more than your pull.
or use nitrous
Old 12-04-2008, 11:29 PM
  #47
wannabuy350z
wannabuy350z's Avatar
if I dont care about break boosting, but would like to do a burn out once in a while, what can I do?
Old 12-05-2008, 03:37 AM
  #48
KPierson
KPierson's Avatar
I would guess that a battery reset would work.
Autozone will clear codes for free with an OBDII reader.
Old 12-05-2008, 02:33 PM
  #49
superchargedg
Damn Noobs
superchargedg's Avatar
Originally Posted by Dynasty.Zero
Those 16g's (or are you running 20g's?) are so stupid responsive for being journal-bearing turbos.
Hope your car doesn't break again.
The Greddys are 18's not 16's.
Old 01-11-2009, 09:44 AM
  #50
specialized5223
specialized5223's Avatar
Which pin is 101? I hav an '03 pin layout ecu. I keep reading that after 2003 its flipped or some retarded ****. I just want to brake boost damn it.
Old 01-11-2009, 12:51 PM
  #51
rrmedicx
rrmedicx's Avatar
RIF = Reading is Fundamental.
Originally Posted by Hal@IP
Above is the layout of what the pins look like when you disconnect the ECU from the harness. So if you are looking for some kind of special fuse box that resembles this you won't find it. Just go under the passenger side dash and locate the ECU, disconnect it and track down the appropriate pin and identify the wire leading out...install a switch and connect to the wire leading to that pin. Now you can easily turn on/off the ability for the computer to read the signal being transmitted when applying the brakes.
Old 01-11-2009, 08:00 PM
  #52
specialized5223
I just unplgged the grey cable under the hood up by the reservoir. Brake lights still work, abs off, tcs off. lol.
Thanks though.
Old 01-11-2009, 08:53 PM
  #53
zmedic16
zmedic16's Avatar
Thanks though.
so you got your brake lights to work but yet ur car wont bog when pressing the brakes and gas at the same time? this sounds like something i want to try since the base model didnt bring traction control anyways.
Old 01-12-2009, 05:40 PM
  #54
punish_her
punish_her's Avatar
The thing is you still keep traction control with the 101 switch, not so much by pulling the grey wire in the engine bay. Its all in what liability your willing to assume. If you wreck and hurt or kill some one and they find that that with ABS you would have stopp in enough time to prevent an accident you will be racked over the coals. At least you still have abs, the only feature seamingly killed with the 101 mod is the panick break feature, eventualy CC if you drive alot with it on.
This should be used as a happy switch and not a driving switch. On only when needed and you should have any problems with only a few exceptions.
Old 02-26-2009, 06:31 AM
  #55
Glex25
Glex25's Avatar
Brake boosting is it BCM specific function or is it handled by the ECU?
Reason I ask is it something that can be manipulated when you flash your ECU
to remove limiters and what not?
Old 02-26-2009, 06:54 AM
  #56
Blwn_By_Twins
Blwn_By_Twins's Avatar
It is controlled by you. You hold the brakes down to stop you acceleration while on the throttle building boost.
Old 02-26-2009, 06:59 AM
  #57
Glex25
Glex25's Avatar
Have you tried pressing the brakes and gas at the same time?
The computer will stop fuel delivery that's why i ask is it something that can be manipulated with a ECU flash
Old 02-26-2009, 09:24 AM
  #58
KPierson
KPierson's Avatar
It is definately a function of the ECU. I've never seen that anyone has been able to reprogram that functionality of the ECU.
Old 02-26-2009, 10:19 AM
  #59
Blwn_By_Twins
Yes I have, but I installed a switch.
Miss understood what you were asking I guess.
Old 02-27-2009, 07:56 AM
  #60
SmallTuner
SmallTuner's Avatar
i like to spool them up with a shot of nitrous
much better
Quick Reply: Brake Boosting FTW!!11
