Problem when revving???
on
Hey guys, I have had my Vortech Supercharger on now for about 3 weeks, and not had a single problem. So I finally got my gauges in, 1 electric boost one and a fuel pressure gauge. I drove my car all day today, and not a single problem. I mounted my gauges last night on my triple gauge pod, but didnt connect them. So I made a couple runs today and when I got home, decided to connect at least my boost gauge to make sure everything is cool. I mounted the boost sensor and wired everything up according to the instructions. I turned on my car, and it turned on fine, but did idle a little different. I started revving it and around 4k rpms, it would like boggle or drag and get out of that stage around 4.5k rpms and rev up the rest of the way. Its definitely not normal. So I decided to drive it around the neighborhood to see if it was a fluke. I would get into boost and around 4k rpms again, it would do that same. It would start building boost, and once it hits 4k it slows down for a bit, and then takes off.
Anyone had a similar issue? I connected the ignition part of my gauge to the cigarette lighter, which is the only thing I can think of that might be screwy, but even then, I dont think it should....
HELP........
HELP........
on
Originally Posted by Mr_pharmD
it might be a boost leak. I would disconnect the vaccum lines from the boost gauge and see if everything goes back to normal. I might have hook it up wrong.
So how the problem was solved ? i have the same issue right now with my SC Z ...Its happening during the tune... 5th and 6th gears...its like when u r loosing traction...and after the few pulls i've started to experience this problem even at 3-d gear... boost l
eak , belt loose ?
eak , belt loose ?
08-06-2021 06:19 AM
