code p0057
on
code p0057
hey guys quick question im gettin code p0057, which means its time to replace an o2 sensor(code=o2 sensor low voltage) . Now the code is for bank 2 sensor 2. I know that the sensor is one of the ones located in the test pipes. however which is bank 2, the driver or passengers side? Also from which direction are you looking at the car, head on or from the drivers seat. thanks for any help.
T0kinha (10-22-2022)
on
Same code here boss...
P0057, so i changed the sensor on the driver's sde after the cat (found the info in forums) and about 10 miles later the light came up again... Ran the scan and the same code was showing...
Is sensor 2 on the test pipe or after the cat??
Can somebody help?
Thanks
Lucas
Can somebody help?
Thanks
Lucas
on
how did you reset the code? In my experience with 02 sensor CEL related, the code always come back after a few days if I just use the ODBII reader to clear it, but If I do the battery disconnect for a few hours/over night, then the CEL stay away.
I agree with Zero260 if you have test pipes and you have fouled out the original o2 sensors then they are done, chances of cleaning them are slim to none to make them reusable. If you have non foulers then your non fouler hole needs to be VERY small, I had this issue and refouled a new 02 sensor and used even smaller holes to prevent the issue on my resonated test pipes which actually worked.
on
I had O2 sensors code come up on my car and changed all four sensors. Code still can on alittle after I rest the ecu after afew mile. End up being a Fing Fuse. make sure to check the O2 sensor fuse
etkms
06-19-2022 06:30 PM
11-09-2020 10:27 AM
350Z Project X
10-17-2015 05:16 PM
