Sorry to bring this back from the dead , but basically to retain the stock multi gauge , you just fit out the volt and oil psi? Does anyone please have a picture of this ? Thanks
I couldn't find the old pics I uploaded.
I hope this one help. (had to edit it online)
You need to break the plastic where the yellow line is to separate the oil press/volt from the trip gauge. then remove the two gauges circled in red. That should give you enough space to fit your gauges. Don't do anything to the green board. Will take pics of the parts later this week when I go back home.
You need to break both the see-through and black plastic where the yellow line is and remove the needles to remove the black portion of the gauge out. IIRC.
So midz350, you got the 60mm gauges correct ? And which way did you snake the wiring ? Thanks .... Doing this soon as my oem oil psi gauge it self craped out even after a new oem pressure install . Smh thanks again
If the 60mm fit why wouldn't the 52's? Anyway shamless plug, if you are after a set of defi gauges complete that have been modified to fit let me know as my set are for sale.
