Fuel Injectors
Old 02-02-2010, 07:06 PM
rtiid22
rtiid22's Avatar
Default Fuel Injectors
Referring to vq35hr:
How much power are the stock fuel injectors good for? (estimate) & at what point does the fuel rail have to be swapped for a bigger one? Thanks.
Old 02-03-2010, 06:09 AM
Dynosty
Vendor - Former Vendor
Dynosty's Avatar
Stock injectors are good for stock power and boltons. Maximum power on stock fuel rails is not a set number. What are you trying to do?
Old 02-03-2010, 06:13 AM
Jasonvs2146
Jasonvs2146's Avatar
Rails um when you go with a fuel return system. I have 540 whp twin turbo setup on my HR with 600cc injectors and stock rails. But I am going to be getting those out for a fuel return system.
Old 02-03-2010, 07:59 AM
rtiid22
rtiid22's Avatar
Thanks guys, I just wanted to know for general knowledge. My goals are 450-500whp and was curious if stock injectors would supply enough fuel with just a fuel pump swap, I guess not. I suppose I'll be perfectly fine with stock fuel rails.
Old 02-03-2010, 08:23 AM
Sharif@Forged
Forged Performance
Sharif@Forged's Avatar
With upgraded injectors, the OEM fuel rails are actually very capable of flowing fuel past the 500whp mark. How much power are are you eventually looking to achieve?
The stock injectors are good for about 300whp.
Old 02-03-2010, 10:48 AM
thom000001
thom000001's Avatar
Is this 450-500rwhp on a SC or a turbo setup? SC setup will require more fuel.
Tom
Old 02-03-2010, 11:22 AM
rtiid22
rtiid22's Avatar
most likely single turbo, what size injectors should I be looking at?
Old 02-03-2010, 11:39 AM
str8dum1
str8dum1's Avatar
if stock block, 600cc, if built, skies the limit
Old 02-03-2010, 11:52 AM
rtiid22
rtiid22's Avatar
yup, stock block; keeping it under 500whp
Old 02-11-2016, 08:42 PM
cincysilvias14
cincysilvias14's Avatar
find a single turbo kit for a hr let me know i want in
Old 02-12-2016, 03:55 PM
Conway_160
Conway_160's Avatar
Boosted Performance?
Old 02-13-2016, 11:50 AM
Juztin
Juztin's Avatar
Ugh for the ancient thread bump. Just go with Gamma Motors TT kit (if you do go thru Concept Z performance as the man in the middle - DO NOT go direct), or AAM. I figured I'd name drop Gamma for OG to get a chance to post a response
Old 02-13-2016, 02:02 PM
R6n350GT
R6n350GT's Avatar
Go boosted performance it has everything you need.
04-22-2021 09:42 PM
11-09-2020 10:27 AM
Quick Reply: Fuel Injectors
