my SC Setup
Old 06-11-2010, 09:17 AM
  #161
maXmood
Under Boost!
maXmood's Avatar
^not bashar.. all i can say is stay away from him.
his name is Ebrahim alga6an.
you're from kuwait?
Old 06-11-2010, 09:24 AM
  #162
rcdash
rcdash's Avatar
There are only a couple of major ground points - on the frame rail, on the timing cover, in the battery compartment, by the ECU, under the gauge cluster. Check the throttle body harness and MAF harness - fully plugged in and nothing pinched? Do you have a 6MT or 5AT (sorry didn't go all the way through the thread). Usually the U1000 CAN codes come along with something else...
Old 06-11-2010, 09:38 AM
  #163
maXmood
Under Boost!
maXmood's Avatar
thanks for the tips.. i think the harness that goes to the MAF is pinched, because it's facing down.
got 5AT.
i've searched the forum for similar problem, but no luck..
i just need this fixed, and then i can have the car tuned to see if there's any progress.
Old 06-11-2010, 09:59 AM
  #164
midz350
midz350's Avatar
you're from kuwait?
I don't know the guy, he tuned my friend's EVO8 and it was smoth.
can you PM me please the words on this guy Bashar.
From Ryiadh.
Old 06-11-2010, 10:04 AM
  #165
maXmood
Under Boost!
maXmood's Avatar
From Ryiadh.
For Evos, you got someone called Rami.. bashar is learning from him.
Rami is known in the Evo scene. he's a great guy, and a great tuner.
for Haltech, you got Ebrahim Alga6an. he tuned lots of FI'ed 350z.
for Uprev/Osiris, you got Julan from PM-Dyno (i think he's in alkhobar). he tuned stock 350z's.. my car is the first FI'ed 350z he's tuning. so, that's another option for you.
Old 06-12-2010, 12:54 AM
  #166
binder
binder's Avatar
my u1000 was front left wheel sensor. It became unplugged. check anything like that. grounds, abs sensors, etc.
Old 06-12-2010, 01:04 AM
  #167
maXmood
Under Boost!
maXmood's Avatar
did it put the car into limp mode?
Old 06-12-2010, 01:18 AM
  #168
binder
binder's Avatar
nah, just disabled abs and vdc. tons of lights on the dash but the car drove normal.
Old 06-12-2010, 02:10 AM
  #169
maXmood
Under Boost!
maXmood's Avatar
that's a description of the problem..
hesitation, stalling or the engine holding a lower than normal RPM. For me, I was cruising at about 45 MPH, the engine dropped to about 500 RPMs, began shuddering, and the SES light came on. The engine did not respond to the gas pedal and at about 15 MPH it stalled. I got over to the shoulder and tried to restart but it did nothing. It was like when you try to start with a completely dead battery; no sound. But I had full electrical power since the lights/radio/air was on. 5 minutes later, it started back up as if nothing had happened. Check Engine light remained on.
Old 06-12-2010, 05:25 AM
  #170
binder
binder's Avatar
hmm....sounds like something's not making a connection. Tons of things on the CAN bus. Maybe tps sensor in the pedal?
Old 06-12-2010, 09:52 AM
  #171
Erdem
Erdem's Avatar
is it limp mode when you can't rev past 2500rpm?
Old 06-12-2010, 12:31 PM
  #172
Vince@R/TTuning
Vendor - Former Vendor
Vince@R/TTuning's Avatar
Double check your ECU connectors...i had the same thing on a 350Z on our dyno and it ended up being the connector was slighly cocked...it was still clipped in and the latch was secure..but it was hanging up on itself near the edge...if that makes any sense...lol
Old 06-12-2010, 12:32 PM
  #173
maXmood
Under Boost!
maXmood's Avatar
TPS = Throttle Position Sensor??
if so, i'm not sure.. really, i can't tell what could be the cause of this. but i've noticed it happen on extreme hot weather conditions. it happend when we were tuning at WOT on a hot day (120F), and it happened again after cruising for a while and temp was about 112F.
so i'm not sure what's causing it.
Old 06-12-2010, 12:33 PM
  #174
maXmood
Under Boost!
maXmood's Avatar
i'm not sure what you're asking.. but i call it limp mode because it feels dead.
Old 06-12-2010, 12:36 PM
  #175
maXmood
Under Boost!
maXmood's Avatar
hmmm... where do i have to start checking exactly? under passenger dash?
what did u end up doing to fix the problem?
Old 06-12-2010, 12:44 PM
  #176
Vince@R/TTuning
We ended up checking the ecu and u could see a slight gap near the end...very slight...undid the connection...checked all the pins and when we relatched the connector we ended up just pushing a lil harder to make sure it was seated...and that seemed to solve our issue...
Old 06-12-2010, 12:53 PM
  #177
maXmood
Under Boost!
maXmood's Avatar
i'll start with this tomorrow..
thanks for the tips!
Old 06-12-2010, 01:27 PM
  #178
midz350
midz350's Avatar
Its the heat bro, your car had a sunstroke .
GL.
Old 06-14-2010, 06:00 AM
  #179
maXmood
Under Boost!
maXmood's Avatar
guys, quick one..
AFR on idle = 14.7- 15.0 is fine?
AFR on partial throttle/cruise control = 14.6 - 14.8 is fine?
only @ WOT i should see 11.xx?
Old 06-14-2010, 06:07 AM
  #180
GT-ER
GT-ER's Avatar
guys, quick one..
Correct.
Quick Reply: my SC Setup
