BigMo350z HR Greddy TT Build!
#121
on
Why not have 3 settings? 5psi is wg pressure I believe. You can just turn the boost controller off to achieve that. IMO, set low boost to 7-8psi (A) and high boost to 10psi (B). You have the EVC correct?
#122
on
Updates- More pics!
^ That's sound like a good idea. Thanks buddy!
Car is ready to tune! Waiting for updates today or tommorrow can't wait to get it back! Some more pics I took during the week..
#126
on
* Guys need your help!
Benchmark tuning is unable to locate the ROM file for my Osiris Tuner Edition for a 2008 nissan 350z apparently its something needed prior to start-up or tune. If anyone can please provide this link or help me locate it would be greatly appreciated! Benchmark is waiting on this in order to get my tune started otherwise it will dragggggg out till monday.. Thanks! What I was told from Up-rev was that the Tuner was plug-in-play also Benchmark has already downloaded all the information from http://www.uprev.com/support.php
Kuhan- It looks like they will not tune my car on the free dyno day because they are stating it will take 4-5 hrs!
#128
on
Yea it seems like it.. I'm the first Osiris tune for them.. I really wanted to expand Osiris business however did not know I would come across this issue to slow down tune time... Hopefully things get sorted out soon starting to get frustrated a bit....
#129
on
Here is the response maybe someone can explain or reply I also recall providing Up-rev my ECU Part Number thought that would be enough.
Here is what benchmark tuning stated
I am currently connected to the ECU and it doesn't show a rom file....
Nothing to edit, it does show your computer code and that the cable is connected, in the ROM folder on the osiris it is blank... this is where the software says ther should be a base file for the purchased license??
#132
Using Cipher for Real Time Tuning.
Once an ECU has been reflashed with an UpRev ROM file the ECU will have extended capabilities that include map switching and the ability to Real Time Tune (RTT). RTT allows for certain parameters to be changed in real time while the engine is running, and even under load.
11.1.
The RTT Window
11.1.1.
Use Cipher to connect to the vehicle.
11.1.2.
Click the button labeled [Tune Car] at the bottom of the main Cipher window.
11.1.3.
A new window should have opened and you should be looking at the “Values” tab. Each tab represents a table or list of values that can be changed in real time.
11.1.4.
Click each tab to view and edit the current values.
11.1.5.
Modifications from the RTT window take effect immediately.
11.1.
The RTT Window
11.1.1.
11.1.2.
11.1.3.
11.1.4.
11.1.5.
#134
on
Ok thanks everyone! I will tried contacting today them however today there are doing a free dyno day event. So my car will have to wait until tommorrow or monday looks like SUX! Feel's like the never ending project! Left them a VM. So will see what happens now..
Here some shots my buddy just took since i'm stuck working! At least I know it's all put together.. something to hold me off for now.. Thanks Kuhan!
#135
on
THANKS !
Just emailed sales@benchmarktuning.com this information posted above looks pretty straight forward hopefully someone takes a look at it today and tune's it tommorrow or I might just be getting my hopes up again..
#137
on
11.1.
The RTT Window
11.1.1.
11.1.2.
11.1.3.
11.1.4.
11.1.5.
11.1.
The RTT Window
11.1.1.
11.1.2.
11.1.3.
11.1.4.
11.1.5.
Update - Reponse from Benchmark Tuning
Yes, that is understood.
But until we have the base ROM we can't tune with the cipher.
Mike
#138
on
Mike called back stating they updated all information and were still not able to locate ROM file. He stated the folder is empty?! On monday Benchmark will attempt to contact Osiris as well as myself to see if we can figure this out. Hopefully someone here has the GOLDEN ROM FILE!
