Cog Belt for Vortech 400% Stronger
Old 03-02-2011, 05:37 PM
str8dum1
str8dum1's Avatar
mmm custom crank pulley. nice! should just cog belt it since you are going that far
Old 03-02-2011, 06:03 PM
slopefunk55
slopefunk55's Avatar
What up Tim. Ysi setup Just curious if your throwing a built engine in and whats your setup going to look like. What kind of cams and compression ratio are you going to be running on your YSI setup? Oh what rpm are you going to be turning that beast at?
Old 03-02-2011, 06:10 PM
slopefunk55
Got to ask more questions. Cant to wait to see a run on this setup. So you are having custom 10 rib pulleys made crank, alt, and ps pump? If you dont mind how much is that going to set you back?
Old 03-03-2011, 06:29 PM
OldManZ350
OldManZ350's Avatar
Yes, it will be a Built Motor. I just in the planning stage so don't expect anything soon. Trying to get all of the mechanical issues worked out with the YSI first.
Cp Pistions 10 or 11 to 1 compression
Carillo Rods
Still will be on the street, so still working on the Cams
Old 03-03-2011, 06:30 PM
OldManZ350
OldManZ350's Avatar
About $1500-$2000 for the Set
Old 03-03-2011, 07:26 PM
350z006
350z006's Avatar
Are you concerned about running that higher compression w/ a potential of up to 35 psi boost?
Carillo Rods
Old 03-03-2011, 08:24 PM
OldManZ350
OldManZ350's Avatar
No, Mustang Guys do it all the Time.......
Dynamic CR is much more Important that Static CR
Old 03-05-2011, 03:27 PM
ohhdangz
ohhdangz's Avatar
Hi Mitch,
Fact: When the car is up to Temp, Cog Belt is Tighter. Do a Test you will see.
Fact: Some people on her a broken belts, of corse from improper adjustment, (Too Tight Cold) so they do Break.
Thanks,
TimRod
Ill have to check when i get back to the states bc i know i have mine setup with the idea it will loosen up...
Old 03-06-2011, 07:50 AM
mafoor
mafoor's Avatar
im guessing this isnt going to be on pump gas lol
Old 03-06-2011, 08:02 AM
OldManZ350
OldManZ350's Avatar
Q16 for the Strip
93 pump for the street
Old 03-06-2011, 06:43 PM
mafoor
mafoor's Avatar
Awsome. Are you going to try to run a wastegate to limit the boost for the street? 30psi with that high of comp just seems a bit much for a pump tune.
Old 03-06-2011, 08:12 PM
OldManZ350
OldManZ350's Avatar
If I have to lower the Boost for the Street, I'll change pulleys.
Old 05-13-2011, 04:25 AM
05Z33
05Z33's Avatar
Do you have the name of the place where you got this new cog belt? I just chewed up my 2nd one, and I'm on my back up belt now. I need to always have one on stand by just in case.
Old 05-13-2011, 08:41 AM
OldManZ350
OldManZ350's Avatar
PM Sent
You should not be Tearing Up the Stock Belt.........My Guess, Too Tight.
I just put a Cog New Belt on after 40,000 miles, it still looked in pretty good Shape.
It is either,
Out of alinement
Too Tight ( Must still have some play after Full Hot, 1/2" play Cold )
or Too loose
Old 05-13-2011, 10:56 AM
binder
binder's Avatar
dang, how am i the last to hear about this ysi setup. That is going to be sick Tim.
Old 01-16-2012, 11:44 AM
mafoor
mafoor's Avatar
Can u pm me the info on the stronger cog belt? I recently had my cog belt shred into about 10 thin strands during a 3rd gear pull, never seen that before. Figure i mite as well get a stronger belt if possible since im turning my t-trim pretty hard.
Old 01-16-2012, 12:45 PM
OldManZ350
OldManZ350's Avatar
Gates 8MGT-608-21 Polychain GT Carbon Belt 8mm Pitch
http://www.vbeltsupply.com/8mmpolychainshort.html
This is the Strongest Belt you can get in this size.
Old 08-26-2013, 04:38 AM
  #38
wizard
wizard's Avatar
Did anyone use this in the end?
This is what's happened to my cog belt at an event recently:
Can anyone recommend the above belt as a replacement?
Old 08-26-2013, 04:43 AM
  #39
OldManZ350
OldManZ350's Avatar
here is a better price.......
Best Strongest Best on the market.......
8MGT-608-21
Gates Part # 9270-1071
Poly Chain GT Carbon Belts - 8M Short Length
0.25 pounds
Price - $26.40 US
https://shop.limct.com/?page=shop/br...3b95961c481de&
Old 08-27-2013, 12:14 PM
  #40
str8dum1
str8dum1's Avatar
if you are breaking cog belts, its too tight.
your serp belt will slip way before you break a properly tensioned cog belt
Quick Reply: Cog Belt for Vortech 400% Stronger
